PUA:Win32/Puamson.A!ml
Norton Fern,
Jul 20, 2022 12:14:38 pm EDT
Windows Defender is now detecting the host file version 7.1.5.0 download and rfusclient.exe with PUA:Win32/Puamson.A!ml. Using Windows 10 64 bit version 21H2 (Build 19044.1826) and RU Viewer 7.1.5.0.
![](/upload/forum/avatar/c42/2020_11_06_0000.png)
Support (Posts: 2830)
Jul 20, 2022 2:21:53 pm EDT
Hello Norton,
We will submit a false positive report to Microsoft with regards to this issue. Please note, that new false positive detections are usually expected when there is a new version out. It takes a few days or even couple of weeks before a/v software learns to recognize new files as harmless. Unfortunately, we don't have much control over this process.
Meanwhile you can add the Host installation folder C:\Program Files (x86)\Remote Utilities - Host\ to the Windows Defender exception list as described here.
In addition, you can also submit a false positive report to Microsoft here as it usually helps to speed up the process of removing false positive detections.
