Use mobile version (Android) to connect to a Custom RU ? Adress book ?
Anousch Dabaghchian,
Aug 24, 2018 4:45:23 am EDT
I want to know if we can connect a mobile version of RemoteUtilities to a custom RU ?
I see the option in the settings but i writed my ID, i can use it on my computer but not on my mobile.
What can i do ?
Thank you already per advance for your help.
Best regards,
Anousch
What can i do ?
Best regards,
Anousch
![](/upload/forum/avatar/6da/2020_11_06_0000.png)
Support (Posts: 2987)
Aug 27, 2018 4:50:39 am EDT
Hello Anousch,
Yes, you should be able to connect to your self-hosted server on the mobile client. Access the properties for the selected connection and choose RU Server.
Aug 28, 2018 2:38:48 am EDT
Hi Conrad,
Yes, i see in the properties we can type the adress of the RU server but when i type it, i can't see the computers who's saved on my server.
How can i use it ?
How can i use it ?
Aug 28, 2018 11:17:26 am EDT
Hi Anousch ,
Could you attach a screenshot or two to explain your point? You can hide sensitive information/addresses on the screenshots before posting them.
Aug 29, 2018 5:01:51 am EDT
Aug 29, 2018 10:28:56 am EDT
Hello Anousch ,
In order to use the server in the relay role you do not have to log in/sign in on it. Simply specify your server address in connection properties and use the Internet-ID of the Host in order to connect.When i type the RU server adress, i don't have any place to login or do something like that.
Sep 11, 2018 11:01:53 am EDT
Ok, but can i have a list like of all my servers who's in my adress book of my custom RU ?
Sep 12, 2018 7:28:51 pm EDT
Hi Anousch,
Not in Android/iOS version yet, sorry. We are working on adding a full fledged address book to the mobile client though.
As for the desktop Viewer you should just switch to the Details view an look/sort using the Connection type column.
Do you mean if you can separate in your address book which hosts connect through which server (public or self-hosted)?Ok, but can i have a list like of all my servers who's in my adress book of my custom RU ?
