Problem while controlling my PC cursor stops
Ali Alqassab, User (Posts: 1)
Dec 11, 2018 10:07:09 am EST
Hi, how are you? hope you're doing well
im having a problem while controlling my PC fr om my other PC
it's like this
PC2 is controlling PC1
PC2 is moving the mouse as he wishes
when PC1 starts moving the mouse it gets back right wh ere it was in PC
I've been using the program for a while, this doesn't happen usually
although it did happen before but then it stops and i forget about it, but when it happens again it's really annoying
both PC's have Windows 7
Remote Utilities Version 6.8
Conrad Sallian, Support (Posts: 3076)
Dec 11, 2018 11:38:19 am EST
Hello Ali,
If you are in Full Control mode, then this behavior is normal. The admin's cursor always takes precedence over the remote cursor. So if the admin's mouse moves even slightly the cursor will return to the current position of the admin cursor regardless of where the remote cursors moves.
However, if you want to let the remote user work without such interruptions you can switch to the View Only mode right on the toolbar:
Problem while controlling my PC cursor stops - 11 Dec 2018 11:37:20
You can also use Alt + F12 key combination to quickly toggle between Full Control and View Only mode.
