Info connection
ziobelo, User (Posts: 1)
Feb 11, 2019 3:38:35 am EST
Hi
I try to use program to control a remote pc but have a strange problem I connect and see all but in a bit the image block and got more seconds of lags from time of put a command to see what happen.
there's same configuration to setup to improve the quality of services?
Feb 11, 2019 1:28:54 pm EST
If you are having issues with performance, please check out this guide: https://www.remoteutilities.com/support/kb/slow-remote-connection-speed-performance/
