Set connection framerate higher than 25 FPS
Hi community,
I've been doing a lot of work through a remote connection to another PC lately, and I was wondering if there was a way to set the remote connection framerate higher than 25 FPS. Theoretically, my connection should be able to handle it, but is 25 FPS a hardware cap?
Unfortunately, it's not currently possible to set the FPS value higher than 25. Sorry for this. As for the hardware cap - I'll check with our developers on this and get back to you with their answer.
Sorry for the inconvenience.
