How to print by virtual printer.
Hello friend,
As i am taking print  on viewer mode ( Local/Client ) computer working on RDP mode  from host ( Server computer) . But could not print on local computer.
How to configure the printer to take print on local computer working on RDP.
Any video or configure steps for the same.
Hello Santosh,
Do you mean that you want to print a remote document on a local printer? If this is the case, please double-check if you have Printer driver installed on your Host machine - you can locate it as Remote Utilities printer in the Windows's Devices and Printers window. Alternatively you can also check this in the Host Settings -> Driver tab - if the virtual printer driver is not installed, i.e. the "Install" button is active, then you can install it by simply clicking the same "Install" button - this will automatically install the printer driver on your Host machine. Here's also a guide on the Remote Printing feature that might be helpful.
