Lastest viewer Not work
RU Server : Windows 7 x64 + Lastest Version (Today update&reboot) + Free License
Agent : Windows 10 x64 21TH2 + Lastest and 7.0.2.0 (Same result)
Viewer : Windows 10 x64 21TH2 + Lastest and 7.0.2.0 (Old version work) + Free License
Old version viewer work well but Lastest version is not work
when i input Internet ID on viewer it seem OK. (Display online)
but I can't connect to Agent. (Display online -> Try connect -> Display 'unable to connect Attemts Left 5~1 -> Display Offline -> Display online again -> endless loop)
I tried remove lastest and reinstall old version all work well
Please, make sure that you specified your RU Server address and port in Agent Internet-ID settings. Perhaps, your Agent still points at our default server instead of pointing at your RU Server.
All Setting is OK. (work well with old version viewer)
Server recognize Agent
Even lastest viewer can detect Agent (Status Online)
but Can't connect that (Changed status Offline)
Lastest viewer Not work Lastest viewer Not work Lastest viewer Not work Lastest viewer Not work
dateno1, you said you are using latest version of RU Server, but your picture shows you are using 3.1.0.0.
Latest version is 3.2.0.0.
Update your RU Server and see if it fixes your issue.
Download RU Server from this page: https://www.remoteutilities.com/download/
I was update RU-Server to lastest but same result
Old viewer work with Windows 7/8.1/10/11 but Lastest is not work with 7/10
Hi dateno1,
Please, send us your RU Server logs. You can find them in C:\Program Files (x86)\Remote Utilities - Server\Logs\
You can zip the entire folder and send it over to us at support@remoteutilities.com
