Internet ID connection not working, Direct Connect Works v6.10 & 7.x
John Brown, User (Posts: 4)
Feb 23, 2022 7:31:34 pm EST
I have paid for subscriptions to v6.10.10 and v7.1  I do NOT like 7.1 for many reasons and have "fallen back" to 6.10.10  For the past 3 weeks, I am totally unable to connect via Internet ID.  Direct Connection works (v6.10 and 7.1)  I have followed every suggestion in the knowledge base, I have confirmed all hosts say they are connected and ready.  I have confirmed ports are open.  Remote systems appear as online until I click them, then they go to offline and despite waiting through the 5 connection attempts, they never connect.  I have been to each remote site, 3 total, 3 different ISPs, systems that have worked since 2015 when I first learned of your product, simply won't connect now.  Uninstalling, running CCleaner, rebooting, reinstalling, following the instructions to cleanup the directory and registry have totally failed.  I see these complaints all over your knowledgebase without resolution.  You have a problem and it needs to be fixed.  It is not a configuration issue, it is not blocked ports, there is something wrong with your "negotiation" phase connecting from a viewer to a remote host via Internet ID.
Feb 24, 2022 8:32:26 am EST
Hello John,
Could you please double-check if your Viewer of version 6 is registered with your commercial license key? It seems like the issue is actually behavior of a Viewer for version 6 registered with a free license key or running in a trial mode, as these two, unfortunately, will not be able to connect to our servers when using version 6 anymore.
Please double-check if you have the correct license key added to your Viewer on the Help tab -> License Key Storage as described here.
