Host program won't open and no right click open on desktop icon
Version 7.6.2.0
After installing host on remote computer I have to manually add the start icon to my desktop and when I double click on it, it won't open.... when I right click on it only the normal desktop options come up with no option that is specific to the remote utilities app...
I clicked the option to integrate with the firewall
basically can't do anything with it.... any suggestions?
thanks..
Hello David,
You are not supposed to click on a desktop shortcut to run the Host. It is run automatically upon installation and by default starts automatically with Windows. Please, review our Quick Start Guide on how to set up a remote connection.
If you are looking for a 'startable' remote module you might want to take a look at Agent. This module is designed for attended-only support and it does require manualy launch in order to be able to accept an incoming remote connection.
