error when running viewer
hello
I just dloaded the last version
Installed on one desktop-a, set as host
then, i tried to connect fr om another desktop-b, all it worked
so, on desktop-a I installed also the viewer.
For about 2 days worked fine.
Today, when trying to connect from desktop-b to desktop-a (wh ere i installed host and viewer both), i can login, i can see the desktop, but mouse and keyboard inputs does not work!
already tried to uninstall and reinstall, nothing
when i run the viewer, it always crashes!
here the error shown
Nome evento problema: APPCRASH
 Nome applicazione: rutserv.exe
 Versione applicazione: 5.6.0.6
 Timestamp applicazione: 52fab0c9
 Nome modulo con errori: KERNELBASE.dll
 Versione modulo con errori: 6.1.7600.16385
 Timestamp modulo con errori: 4a5bdbdf
 Codice eccezione: 0eedfade
 Offset eccezione: 0000b727
 Versione SO: 6.1.7600.2.0.0.256.1
 ID impostazioni locali: 1040
 Informazioni aggiuntive 1: 4d03
 Ulteriori informazioni 2: 4d0374dd19246e8a1d3ff705632a4111
 Ulteriori informazioni 3: ba64
 Ulteriori informazioni 4: ba64954b298df24d86a15cc218371064
other pop up error
exception ethread in module rutserv.exe at 000D20CC
thread error: handle non valido (6)
any suggest?
Edited:paolo sioli - Jul 18, 2014 11:35:05 am EDT
Hello Paolo,
Could you please perform the following steps:
1. Check in Settings for Host -> Security -> Modes tab. Full control checkbox must be unchecked.
2. Reboot your Host machine.
Try to run Viewer by executing "rutview.exe" as an administrator. You can find this file in your Viewer installation folder.
