Ctrl Alt Del - Does not work
Jeff X,
User (Posts: 9)
Oct 19, 2015 7:27:09 am EDT
I've been testing the product for a few hours and like the features but a very important one does not work.
Ctrl Alt Del (CAD) does not work with Remote Utilities agent to unlock Windows. I tried using the Windows Viewer and the Android app.
CAD does work with TeamViewer's QS agent so it should work without having to install any host software on the remote.
I did search the forums for a solution but it looks like this has been an issue for quite sometime and it was supposed to have been fixed already. I found a post where someone recommended using the on-screen accessibility keyboard but CAD only works when sitting in front of the remote and using its mouse.
This is a real deal breaker, guys
Edited:Jeff X - Oct 19, 2015 7:53:43 am EDT
Jeff X,
User (Posts: 9)
Oct 19, 2015 12:52:45 pm EDT
Using the portable host and the agent. Both systems are Windows 7 x64.
Support (Posts: 3049)
Oct 19, 2015 2:33:12 pm EDT
You probably meant portable Viewer (on the local side), correct?
Jeff X,
User (Posts: 9)
Oct 19, 2015 2:36:56 pm EDT
Oct 20, 2015 9:18:36 am EDT
Hi Jeff,
Currently, the Agent doesn't support CAD. But we'll see what we can do to implement CAD support for the Agent.
