How to run another IP from the same LAN
Efraim Ie, User (Posts: 2)
Mar 02, 2018 4:48:46 pm EST
I try to run another IP address from the same LAN instead of mine but I can not
Conrad, Support (Posts: 3049)
Mar 02, 2018 4:59:38 pm EST
Hello Efraim,
Could you please clarify what you mean by running another IP address?
Mar 03, 2018 2:14:45 pm EST
Hello Conrad,
When I add my laptop IP as a new connection everything is OK, but when a add my mobile phone or other IP address from the same LAN the status is always offline.
Mar 05, 2018 6:20:17 am EST
Hello Efraim,
With Remote Utilities you cannot connect in to your mobile phone. You can only connect from it to a remote PC using Remote Utilities mobile client. It does not make sense to add your mobile IP address to the Viewer address book.
