Hi All
Please can you help in fixing an issue with Remote Utilities software I have. The software is installed to allow connection from a local PC to a remote PC.
After a restart the Software fails to connect giving error 'Idle or Offline'. It takes another restart for software to connect. I have looked through the logs and its keep showing errors:
Exception: Socket Error # 10054 Connection reset by peer. (EIdSocketError).
Exception: Access violation at address 008C5A68 in module 'rutserv.exe'. Read of address 00000030 (EAccessViolation).
