Default Connection Mode
Benny Tucker,
User (Posts: 43)
Mar 11, 2017 11:11:27 am EST
Support level: Plus
Hello Conrad:
One feature I would love to see, is the ability to change the default connection mode. In other words, If I use mostly RDP, when I double click on a connection, it connects in RDP mode, or If I'm doing mostly file transfer work, then I could change the default to open in file transfer mode with double click.. Same for full control, view only, terminal, etc. etc.
That would be great !!!
Love the program...
Love the program...
Ashley Cooper,
Jan 08, 2025 6:05:50 pm EST
Is this option available yet. Mine opens to file transfer by default and would prefer full control.
Support (Posts: 3148)
Jan 09, 2025 10:03:49 am EST
Hi Ashley,
You can select the default connection mode for the double-click action by choosing the connection mode in the Viewer toolbar ('ribbon').
For example, if you select 'View Only' in the ribbon, and then double-click on any item ('connection') in your address book, a remote session will start in the View Only mode.
