I've tried the fix others have had work but it won't for me - license
Dave, User (Posts: 2)
Apr 01, 2021 2:03:45 pm EDT
I've tried the removing the config_4 file after exiting Viewer to install my free license, the 31 day trial is back - but I can't add the license file when I drag it.  I tried opening the license file in Notepad and copying the text as well and that didn't work for me either.  Any suggestions?
Apr 01, 2021 6:35:28 pm EDT
Hello Dave,
Could you please clarify what version of Remote Utilities do you use? In case if you use version 7.0.0.3, please note that your license key from version 6 is not compatible with it. In this case, please generate a new key using this form. You will receive your key as file with a .rlicense extension - with this key you can register your Viewer as described here.
Apr 06, 2021 9:15:51 am EDT
That helped very much!  I had version 6.1 and I just upgraded and was able to use the generated license.
Apr 06, 2021 4:25:27 pm EDT
Hello Dave,
