Doesn't work on Samsung Galaxy SIII mini
Michael Cat, User (Posts: 4)
Jun 30, 2015 3:09:00 pm EDT
Hi! Remote Utilities is a great tool, but unfortunately viewer doesn't work on Samsung Galaxy SIII mini phone (model number GT-I8200, Android 4.2.2). Application shows logo screen for 2 seconds and then exits without any messages.
Jul 01, 2015 1:33:24 pm EDT
Hello Michael,
Does restarting the device or re-installing the software from Play store work?
Jul 01, 2015 3:07:12 pm EDT
No, I'v tried both reinstalling and device restart, none helps (
Jul 02, 2015 3:01:50 pm EDT
Hi Michael,
Unfortunately, we can't help with this because apparently this has something to do with the underlying IDE /environment that we to build the Android app. I recommend you waiting till the next update of Android app.
Oct 18, 2015 2:06:48 am EDT
Still doesn't work after last update.
Oct 18, 2015 12:52:49 pm EDT
Hello Michael,
I forwarded your report to our developers and asked for input. I'll keep you updated.
Oct 18, 2015 2:02:38 pm EDT
Michael,  could you please provide the version number of Remote Utilities app that you installed?
Oct 21, 2015 7:13:20 am EDT
Hello! Sorry for delay. Android application - 11.12 as my phone shows in apps manager. Host - v.6.3.0.6.
Oct 21, 2015 3:55:30 pm EDT
Hello Michael,
We will try to reproduce the issue but there is a good chance that this issue is caused by the framework/IDE that we use. We will try to determine if that's the case.
