Remote Utilites Seems to connect to wrong port
ryan soukeroff, User (Posts: 2)
Feb 15, 2017 5:42:17 pm EST
i have set up my android remote utilities to connect to my server remote.servername port 443, but it will never connect. i check the log file and error message read as below, 445 seems to me to be the wrong port than i have entered. my iOS device connects fine.
15-02-2017_15:30:40_538 InetConnection to internet-id server error. Name: "101-356-232", host: "Http://remote.servername.com:445". Exception class: "EIdResolveError". Message: "Error resolving Address :  (7)".
15-02-2017_15:30:40_539 Connection to "101-356-232" failed.
Edited:ryan soukeroff - May 10, 2017 3:28:47 pm EDT
Conrad, Support (Posts: 3049)
Feb 15, 2017 7:20:21 pm EST
Hello Ryan,
You need to remove http:// part.
Feb 16, 2017 5:14:44 pm EST
i have not entered in the http:// part
i reentered the server name and tried again. see problem
16-02-2017_15:12:07_281 InetConnection to internet-id server error. Name: "101-356-232", host: "Http://remote.servername .com:445". Exception class: "EIdResolveError". Message: "Error resolving Address :  (7)".
16-02-2017_15:12:07_281 Connection to "101-356-232" failed.
Edited:ryan soukeroff - May 10, 2017 3:29:02 pm EDT
Feb 16, 2017 5:37:44 pm EST
Hello Ryan,
Are you trying to connect from the same network or from different networks? If the former, try to connect to a different network (if you are on Wi Fi, switch to 3G/LTE, or vice versa) and try the same.
Also, could you send a screenshot of your mobile app's server settings window? You can send a screenshot via a private message or to support@remote-utilities.com
