Upgrade Free v6 to v7 Licence Key Email Not Received
I've just upgraded Remote Utilities Free v6 to v7 and have not received the licence key email.
I tried twice and did check the spam mail box. I waited ten minutes between attempts just in case the email was slow.
What should I do?
Regards,
John
What should I do?
Regards,
John
Hello John,
Could you please send us an email to support@remoteutilities.com specifying the email address that you've tried using for generating a new license key? This way we can look it up in our database.
Just to let you know that I sent the email to support about twelve hours ago.
I trused you received it and the problem is being investigated.
Regards,
John
Regards,
John
Hello John,
Please note that I've replied to your email from an email address m******@*****l.com yesterday, soon after you've emailed us to the support address. I'll copy the email's content here as well just in case:
Alternatively, as a temporary solution, please try using another email address hosted with another provider in order to generate your license key (for example Gmail).
It seems like your email provider is mistakenly blocking any emails coming from addresses with the domain *remoteutilities.com, hence why you haven't received the license key emails as well as our response. Please double-check with your email provider to see if they're blocking emails from us and ask them to remove our email addresses from their blocklist.I've checked in our system and I see that there were two emails successfully sent to the email address mtrsoft@fitall.com earlier today. I've tried re-sending an email to the same email address just in case — could you please double-check it once again to see if you've received it? If there's still no email, then it might be caused by your email provider blocking the emails — in this case, please try using another email address hosted with another provider (for example, Gmail).
My ISP was blocking the email. It didn't even let it through to the spam folder.
Thanks again,
John
Thanks again,
John
