Cursor
I am using Viewer (7.1.2.0). I have been using the remote application to remote into my work computer with (2) monitors. Just  today I am unable  to use my cursor on one of my remote  monitors. I do not know  if I  accidentally hit a key.
Any suggestions?
Thank you
Hello Angela,
Please make sure that you use the Full Control connection mode and not the View Only mode when accessing your remote Host machine.
In addition, please try enabling the Use legacy capture mode feature and see if this helps to resolve the issue, You can enable it in the Host Settings -> Other tab. After enabling the feature please make sure to restart Host in order for the changes to be applied. You can also enable the feature via Remote Settings - in this case Host will be restarted automatically after the changes are made.
