Windows Agent log file time entries
William Eigenmann,
User (Posts: 6)
Dec 07, 2023 7:35:10 pm EST
Support (Posts: 2864)
Dec 07, 2023 8:25:11 pm EST
Hello William,
The default time zone used in log files is UTC. Could you please let us know what is the time zone where your Agent machine is located?
William Eigenmann,
User (Posts: 6)
Dec 07, 2023 11:47:28 pm EST
Hello Pauline,
thanks for your reply.
All is located in Australia. In fact they are on the same physical machine running Proxmox.
So an Agent is running in a virtual machine Windows 10. The Viewer is on another vm also Windows 10.
I have setup another vm also Windows 10 to be a dedicated RU server. All going through that.
I am using a Free license for up to 10 connections.
I only started off using Remote Utilities yesterday.
[censored] is giving me hard time and I am in need for a better friendlier solution.
Dec 08, 2023 12:33:23 pm EST
Hello William,
I’ll additionally check with our developers regarding the time display in logs.
I’ll get back to you with an update on this shortly.
