Can you get HOST ID from a Powershell script or command prompt?
Arthur Torres, User (Posts: 2)
Feb 15, 2024 12:15:31 pm EST
Can you get the HOST ID from a Powershell script or command prompt remotely? I would like to install RU HOST on a new computer and then have a script that will run against the same newly imaged machine and send me the RU ID for that new install. I know you can have it emailed using the .msi configuration tool but is there a way to do it via PS1 script, command prompt or batch file?
Pauline, Support (Posts: 2887)
Feb 15, 2024 4:20:10 pm EST
Hello Arthur,
Unfortunately, Remote Utilities doesn’t provide such functionality yet. However, I’ll forward your request to our development team for review to see if we can implement it in our future updates.
Currently, you can obtain an Internet-ID code by generating it manually in the Host Settings or by using the MSI Configurator Tool.
