Self-Hosted Server - recover from backup
Hi RU community
Our server which was hosting the RU Self-Hosted (relay and address book sync) gave up the ghost over the weekend so we're having to stand up a new server and recover fr om file-level backups.
Ideally I was hoping that we'd be able to reinstall RU Self-Hosted Server and pull it's datastore/settings/addressbook/users etc off backup and restore them, but to be honest I don't know wh ere it's datastore is, can somebody point me in the right direction?
Thanks in advance!
Thanks in advance!
Hello Tyson,
To migrate your address book(s) and sync settings, copy the contents of this folder:
As for relay, actually there's nothing to migrate there because the relay function is not supposed to save and keep any data. In this role the server simply forwards remote access packets.
C:\Program Files (x86)\Remote Utilities - Server\datato the same location in the new installation. You can also copy the Logs and Stat folders if you need the logs.
Hi Conrad,
Absolute Legend! That did the trick brilliantly, we're back up and running barely an hour later without batting an eyelid.
Thanks heaps for your quick answer
