Viewer remote to host immediately sleep by moving mouse
Phann Channrithy, User (Posts: 2)
Mar 01, 2018 2:50:14 am EST
I use viewer 6.8.0.1 in order to remote to Windows 10 pro's host. After I can remote to that PC, I use mouse to control that PC immediately sleep or sign off( I'm not sure).
I hope you will find the solution for me.
Thanks for your help
Conrad, Support (Posts: 3088)
Mar 01, 2018 3:41:01 am EST
Hello Phann,
Thank you for your post. Could you please clarify what the issue is?
Mar 01, 2018 4:19:09 am EST
Hello Conrad,
My main issue is what I want to know that's why I remote to other pc just only moving mouse that pc is sleep immediately. I's my issue. Can it cause from Windows or RemoteUtilities?
Mar 01, 2018 5:05:27 pm EST
Hi Phann,
I'm not sure this is caused by Remote Utilities. The program doesn't affect or change your power options or screensaver settings.
