Host don´t change to Current User in Terminal
Dear, I have a host machine that either doesn´t change from System to Current User in Terminal, or the menu shows it changed, but "> whoami" always shows System. It is a Win 8.1 machine.
Other hosts in the same session work OK (all Win 10...).
Does anybody know if I can do something to fix this?
Thank you!
Thank you for the report. We will test it and get back to you.
Unfortunately, we couldn't reproduce this issue. What Host version do you have? You can view the Host version if you right click on the Host icon in the system tray and select "About Remote Utilities...".
It is the only Win 8.1 machine I have, but I´ve seen that on a Win 10 as well.
Thank you!
Hi Agomes,
That is what I thought.
I will upgrade shortly to 6.9 and see what happens.
Good News!
It is working fine with Host 6.9b.
Thank you!
