Keyboard key combination issues
Jim Chan, User (Posts: 1)
Jul 01, 2014 9:55:25 pm EDT
I tried Remote Utilities and generally satisfied with its work, however there is a problem since yesterday.
Host and client both have Windows 7. None of the key combinations with Shift
and Ctrl keys and both Enter keys do not work in remote session.
So, there is no way to enter capital letters from keyboard, no functionality like Ctrl+C or Ctrl+V and no way to execute something using Enter key. Tried to reinstall, restart, reconnect - nothing helps.
Please advise.
Edited:Jim Chan - Jul 01, 2014 9:56:56 pm EDT
Anton Kalugin, User (Posts: 209)
Jul 02, 2014 8:31:11 am EDT
Hello Jim,
Thank you for your message
Could you please try to connect to another remote computer and check this issue. That will help us to determine the cause of the problem.
Sulley, User (Posts: 2)
Aug 01, 2018 1:20:43 pm EDT
Were you able to investigate this issue and find a reason of the problem?
I have the same issue.
Enter, Shift and Ctrl keys do not work in remote session.
Windows 7 x64 with all the latest updates on both computers (host and client).
The latest version of RU - 6.8.0.1.
No antivirus software installed.
Any ideas?
Please advise.
Conrad, Support (Posts: 3034)
Aug 02, 2018 11:51:28 am EDT
Hello Sulley,
Are there any other utilities/software installed that may use the keyboard or clipboard somehow? Like clipboard helpers, touch-typing learning apps etc.
Aug 02, 2018 12:11:37 pm EDT
Hello Conrad,
No, I do not have such utilities installed.
The only thing I could think about is T**mViewer. I tried to exit T**mViewer and stop T**mViewer service, but this didn't help to solve the problem.
Also I should mention, that on another PC I have T**mViewer installed as well, but RU software works fine there. So, I believe, T**mViewer is not the reason of the issue.
Looks like something specific to this computer. But I can't imagine where to look at...
Edited:Sulley - Aug 02, 2018 12:18:26 pm EDT
Aug 02, 2018 5:07:50 pm EDT
Hello Sulley,
That is no doubt. We were never reported of any conflicts with any remote access software, including TV.
Thomas Marullo, User (Posts: 8)
Aug 09, 2018 2:17:18 pm EDT
I just installed the latest versions of the host and viewer on a combination of Windows 10 and Windows 7 64bit systems. I can confirm that Shift, Alt, Ctrl and Enter keys are not working problem from Viewer to multiple Hosts. I can get the key to work once then it doesn't at all, ie. Enter will work once but never again in the current session.
