keyboard shift key
Michael Taylor, User (Posts: 50)
Jan 22, 2014 8:52:06 pm EST
I just noticed when I need to type a capital letter I usually use shift key but its not working, also if I need to type a sybol I would type shift+4 for $ but  it doesn't seem to work on any of my host computer when using the viewer
I just noticed 5.6.0.5 was released this version seems to have fixed this issue
thank you
Edited:Michael Taylor - Jan 22, 2014 9:02:29 pm EST
Conrad Sallian, Support (Posts: 3034)
Jan 22, 2014 10:32:55 pm EST
thank you
Hi Michael,
You are welcome. If the issue comes up again, don't hesitate to let us know.
Matt Latt, User (Posts: 1)
Mar 18, 2015 3:48:43 pm EDT
I have the version 6.1.0.3 and I experience exact same issue. Basically all modifier key like ALT, CTRL, SHIFT don't work. I mean I have machines with password which contains "!" and I simply can't login as windows 8 does not allow to paste via right click paste... the CTRL + V doesn't work so I am in trouble because the machine is like 200km away from me
EDIT: Viewer PC reboot solved the issue.
Edited:Matt Latt - Mar 18, 2015 3:58:22 pm EDT
Mar 18, 2015 5:46:21 pm EDT
Hello Matt,
Quick question - did you reboot the machine since you installed the Viewer? I.e. was it a first reboot since installation?
That could probably help us find the cause of the issue.
Thomas Marullo, User (Posts: 8)
Aug 09, 2018 2:30:38 pm EDT
I'm searching through the forums and finding a few of these posts because I have the same issues. Does anyone know what the resolution is? I can't seem to find one.
Chris D'Avanzo, User (Posts: 1)
Aug 22, 2018 10:02:06 am EDT
same here.  v6.8.0.1 remoting from W7 desktop to W10 desktop
Conrad, Support (Posts: 3034)
Aug 22, 2018 10:55:26 am EDT
Hello Chris,
Do you use any keyboard/mouse sharing or KVM software, like Synergy or ShareMouse? Note a similar thread here.
