how to capture remote audio
marco, User (Posts: 37)
Aug 30, 2018 8:15:23 am EDT
Hi all,
I get the free version of RU
started the portable viewer and installed the .msi host on server, both client and server have win7pro
once connected, full control, I started the audio capture feature but it seems not to work...
no audio from mic no sounds from pc
do you know what I should do/enable?
thank you
marco
Edited:marco - Aug 30, 2018 8:31:01 am EDT
Conrad, Support (Posts: 2991)
Aug 31, 2018 3:25:40 am EDT
Hello Marco,
Thank you for your post. Did you try with the current beta version?
https://www.remoteutilities.com/download/beta.php
Aug 31, 2018 6:42:37 am EDT
Hi Conrad and thank you for your suggestion!
I will try soon!
just a doubt: is it correct to use the viewer (on my pc) and the host on the server? do I also need the RU server?
Aug 31, 2018 9:22:23 am EDT
i just tried launching portable beta viewer and remotely installing beta host .msi
not used RU server package
the same behaviour, if i click on "audio capture" no sounds from remote pc (what I would like is to hear when someone speak into the mic)
More, once connected, I also tried: "other modes" - "remote camera", but I got an error, copied following:
Error report - Remote Utilities Viewer
Class: EInvalidCast
Text: Invalid class typecast.
Version: 69011 (1)
Date: 31-08-2018 15-16-23
do you know what is it?
Edited:marco - Aug 31, 2018 9:27:17 am EDT
Sep 01, 2018 6:27:09 am EDT
Hello Marco,
Yes, correct. No, you don't have to use the self-hosted server for the Internet-ID connection, because you can connect via our public infrastructure (the default option).
Remote sound capture means capturing remote playback (sound produced by output devices).
Remote camera mode has been discontinued.
Sep 03, 2018 4:07:10 am EDT
thank you very much Conrad for the clarifications
Anyway I would to proceed using beta version, very good version!
bye
marco
