how to capture remote audio
marco,
User (Posts: 37)
Aug 30, 2018 8:15:23 am EDT
Hi all,
I get the free version of RU
started the portable viewer and installed the .msi host on server, both client and server have win7pro
once connected, full control, I started the audio capture feature but it seems not to work...
no audio from mic no sounds from pc
do you know what I should do/enable?
thank you
marco
thank you
marco
Edited:marco - Aug 30, 2018 8:31:01 am EDT
Support (Posts: 3074)
Aug 31, 2018 3:25:40 am EDT
Hello Marco,
Thank you for your post. Did you try with the current beta version?
https://www.remoteutilities.com/download/beta.php
marco,
User (Posts: 37)
Aug 31, 2018 6:42:37 am EDT
Hi Conrad and thank you for your suggestion!
I will try soon!
just a doubt: is it correct to use the viewer (on my pc) and the host on the server? do I also need the RU server?
I will try soon!
marco,
User (Posts: 37)
Aug 31, 2018 9:22:23 am EDT
i just tried launching portable beta viewer and remotely installing beta host .msi
not used RU server package
the same behaviour, if i click on "audio capture" no sounds from remote pc (what I would like is to hear when someone speak into the mic)
More, once connected, I also tried: "other modes" - "remote camera", but I got an error, copied following:
Error report - Remote Utilities Viewer
Class: EInvalidCast
Text: Invalid class typecast.
Version: 69011 (1)
Date: 31-08-2018 15-16-23
do you know what is it?
Class: EInvalidCast
Version: 69011 (1)
Edited:marco - Aug 31, 2018 9:27:17 am EDT
Sep 01, 2018 6:27:09 am EDT
Hello Marco,
Yes, correct. No, you don't have to use the self-hosted server for the Internet-ID connection, because you can connect via our public infrastructure (the default option).just a doubt: is it correct to use the viewer (on my pc) and the host on the server? do I also need the RU server?
Remote sound capture means capturing remote playback (sound produced by output devices).the same behaviour, if i click on "audio capture" no sounds from remote pc (what I would like is to hear when someone speak into the mic)
Remote camera mode has been discontinued.More, once connected, I also tried: "other modes" - "remote camera", but I got an error, copied following:
marco,
User (Posts: 37)
Sep 03, 2018 4:07:10 am EDT
thank you very much Conrad for the clarifications
Anyway I would to proceed using beta version, very good version!
bye
marco
bye
marco
