Frequent disconnects
Hi Thierry ,
Steps to fix connectivity issues (or rather pointers that help understand where to look at) are available in our knowledge base:
Cannot connect using Internet-ID connection
Cannot connect using direct connection
The primary source where to look at whenever you have any connectivity issues is the  Host log. Does it have any errors?
Yes,  I frequently get this error code:
28.12.2018---02:35:40:681 96 Internet-ID ErrorCode <> 0 Error code: 1
What does it mean? How can I fix that?
Hello Thierry ,
This error means that the Host cannot connect to the intermediary relay server. There should be other errors in addition to that one. Could you please send us the complete log at support@remote-utilities.com.
I am having this same issue. Was it ever resolved?
Hello Manuel,
I can see that you have also created a ticket.  I will respond in the ticket then.
Manuel,
No luck here.. I have been told the problem is my network although I have been using competing products without an issue.. No help beyond that... If you find a solution, please let me know.
Hello Thierry,
I am sorry, but the fact that competing solutions work doesn't necessarily mean that Remote Utilities may not be blocked on a router or antivirus/firewall software level or otherwise. We don't know the specifics of your network, your router firmware, security settings, corporate policy, IP/website filtering policy - the list goes on and on. How are we supposed to resolve these issues while not having access to the environment itself? It's only the system administrator of that specific network who can help you figure out why a standard TCP/IP application such as Remote Utilities cannot (or isn't allowed to) send packets to a remote server (or directly to Host for that matter).
