Failed to initialize authorization process
- https://www.remoteutilities.com/support/docs/ports-used-by-remote-utilities/#Internet-ID_connection_ports
- https://www.remoteutilities.com/support/kb/socket-error-11001-host-not-found/
Damian Fudali,
Mar 31, 2020 6:25:26 am EDT
I see computer online but when i try to connect i see that message:
remote utilities failed to initialize authorization process
Log's here:
[log hidden for privacy]
Log's here:
Support (Posts: 2886)
Mar 31, 2020 3:27:05 pm EDT
Hello Damian,
Could you please let us know what version of Remote Utilities do you use? Please make sure that you update Viewer and Host to the most recent version - as of this writing, it's 6.10.10.0 or 6.12 Beta 1 version.
In addition, before we proceed to further troubleshooting, please try referring to this KB troubleshooting guide and see if any of the solutions listed there help to resolve the issue.
Namely, we recommend that you check if the required outbound ports are opened and not blocked by your firewall/not used by another software. For more information on the required ports please refer to this Documentation page.
Damian Fudali,
Apr 01, 2020 9:05:17 am EDT
Viewer version is 6.10.10.0
Host - I can't check it because i havo no access for that computer
Apr 01, 2020 5:57:47 pm EDT
Hello Damian,
Unfortunately, it seems that the issue is rather on the remote Host's side and not on the Viewer's side.
In order to isolate the issue, could you please try connecting to the remote Host using the Portable Viewer and see if you're able to connect this way? The Portable Viewer is available for the download on this page.
Damian Fudali,
Apr 02, 2020 3:08:47 am EDT
Unfortunately, still the same.
Apr 02, 2020 2:37:39 pm EDT
Hello Damian,
Thank you for the update.
Unfortunately, in this case, there's not much we can do to help to resolve the issue as the issue, perhaps, occur on the remote Host's side, but there's no access to the remote Host or its logs for further troubleshooting.
If you happen to access the remote Host machine, then please refer to this KB troubleshooting guide first.
Please feel free to let us know if there are any updates on the issue.
Nenad Stevic,
Apr 02, 2020 4:02:07 pm EDT
I have the same Issue.
I have 2 Computers. I can connect with my old computer but not with my new one.
I need both of them to work from home (me and my wife).
Ports 5650,5655 and 433 are as an exception in the Windows Firewall.
Its the full Version of the Software
Log:
Exception class: "EIdSocketError". Message: "Socket Error # 11001
Host not found.".
Log:
Host not found.".
Apr 02, 2020 5:21:36 pm EDT
Hello Nenad,
Please try referring to this troubleshooting KB article and see if any of the solutions listed there helps to resolve the issue.
In addition, please note that we've partially removed the logs contained in your message - please do not publish your logs on the forum as they are considered personal information. If necessary, the logs can be sent to us to support@remoteutilities.com.
Please let us know if the solutions from the article above did not help and the issue still persists.
Nenad Stevic,
Apr 03, 2020 2:53:50 am EDT
Hi Polina,Polina Krasnoborceva wrote:
Hello Nenad,
the host must be running fine because i have access to my desktop over my old computer. With my new one there is this error as shown in my prev. message.
How can this be?
Apr 03, 2020 5:31:43 pm EDT
Hello Nenad,
Could you please let me know if you also use an Internet-ID connection when connecting to the remote Host machine fr om the Viewer on the old computer?
In addition, could you please double-check if it possible to connect to any other remote Host via Internet-ID connection from the Viewer machine wh ere the issue occurs?
