Agent run under local system account
Jia Lin Leong,
User (Posts: 9)
Dec 04, 2020 3:16:44 am EST
Hi,
When I ran the agent.exe and pressed the 'Yes' button on the UAC, I found that the rutserv.exe is always running under SYSTEM (img2) instead of my normal user admin account "user". Is it possible to just let it run as normal admin user account like other applications
(img1) whereby I can still can do the admin privilege task such as run cmd as admin (if I pressed 'No' button on the UAC, I cannot run client's cmd as admin)?
Thank you for the time and patient.
Jia Lin Leong,
User (Posts: 9)
Dec 04, 2020 4:54:14 am EST
Hello Jia Lin,
Please note that you need to have elevated admin privileges when using Agent in order to perform actions that require admin rights. In order to do so, you can use the Restart Agent as... feature or simply use Host instead.
In addition, please note that if you click "No", then both rutserv.exe and rfusclient.exe processes are running under your current user, not under System - this means you're running Agent with no elevated privileges and, therefore, cannot perform any tasks that require such privileges. Here's also a related KB page that might provide some useful information.
Jia Lin Leong,
User (Posts: 9)
Dec 08, 2020 4:39:43 am EST
Hi,
But why it will run under SYSTEM instead of 'user'? (since my pc is already running under 'user' which is already an admin user)
Hello Jia Lin,
This is expected behavior since you're running Agent under an account with admin rights - if you want to run Agent specifically as "User", you simply need to choose "No" option on the UAC prompt that appears upon the Agent's launch.
Alternatively, you can also create an account with no admin privileges, so this way Agent will always run as "User" unless you use the "Restart Agent as..." feature and enter the admin credentials.
