Beta testing: Remote Utilities for macOS/Linux
Feb 19, 2021 11:47:51 am EST
Hello Chris,
The other issue is after a restart of the Windoze box, the Mac viewer will connect, but the window stays blank and won't connect.
Could you please try enabling the Use legacy capture mode feature in the Host Settings -> Other tab and see if this helps to resolve the issue? Please make sure to restart Host after enabling the feature in order for the changes to be applied.
Does Mac Printing work ok?
Unfortunately, the remote printing feature is yet to be implemented for the Viewer for Mac/Linux. However, we'll make sure to add this feature in the subsequent Beta version or final releases. You can find the full list of features that have been currently added to Viewer for Mac/Linux on this page.
Also needing Host for Mac right away of course.
Host for Mac/Linux is currently in development. Unfortunately, we cannot provide a specific ETA on the Host's for Mac/Linux release yet, but we'll do our best to provide it as soon as possible. Sorry for keeping you waiting.
This seems like more of an Alpha. I frequently can't connect, where a small white window sits for a long time. Even go to a large white screen and have the same issue. I've only dabbled with it a few times and It is hang city.
Could you please let us know what version of Host and RU Server do you currently use? In case if you use version 6.10.10.0 or an older version, please try updating your Host and RU Server to the most recent 6.12 Beta 4 and 2.9 Beta 4 versions respectively to see if this helps to resolve the issue.
The latest 6.12 Beta 4 version (and 2.9 Beta 4 for RU Server) is available for download on this page.
Then I connect, and the keyboard on my VM on the host is way screwed up, yet not on the Host. I connect with another remote control app, and no problem at all.
Could you please let me know if you use any keyboard layout or language that is different from the standard English (US) layout? We've been reported a few issues regarding the keyboard layouts in different languages, these issues will be fixed in the next updates for Viewer for Mac/Linux.
Feb 19, 2021 11:59:31 am EST
Hello Sam,
I've seen quite a few hangs, which I didn't realise wasn't actually normal until I used the windows version more frequently.
Sometimes connecting seems slow.
Could you please clarify what version of Remote Utilities do you use for your Windows machines? In case if you use version 6.10.10.0 please try updating to the most recent 6.12 Beta 4 version as it might improve the overall connection speed and performance.
Version 6.12 Beta 4 is available for download on this page.
Sometimes it is frustrating to see my machine bookmark disappears -- I think the main window is acting on a delete key command unintentionally why the session is in progress perhaps?
Could you please elaborate on this a bit more? Do you mean that connection entries get deleted from your Viewer's address book when you press the "delete" key while connected to a remote Host?
Feb 19, 2021 12:01:22 pm EST
Hello Daniel,
Is there just a setting I need to set somewhere that I missed?
In addition, please try updating your Host to the latest 6.12 Beta 4 version as well. The latest 6.12 Beta 4 version is available for download on this page. In case if you use other Remote Utilities modules for Windows, such as Viewer or RU Server, please make sure to update them to the same version as Host as well in order to avoid the version mismatch that might lead to performance issues or some feature not working.
ChrisBS, User (Posts: 5)
Feb 19, 2021 5:07:55 pm EST
Hi Polina,
I just installed and used the latest betas I saw on your site.
Turned on Legacy and will see.
"Unfortunately, the remote printing feature is yet to be implemented for the Viewer for Mac/Linux. "
I need this asap, so will have to explore another Mac solution for part of my needs.
"Could you please let me know if you use any keyboard layout or language that is different from the standard English (US) layout?"
Canadian English, US Keyboard, a common standard here.
Thanks Polina!!
Edited:ChrisBS - Feb 19, 2021 5:08:24 pm EST
Feb 20, 2021 12:23:10 pm EST
Hello Chris,
Of course, please feel free to let us know if there are any updates on the issue.
In this case, could you please elaborate a bit more on the issue, e.g. what specific issues with which keys occur or how the issue manifests itself in other details? Then we could try to reproduce the issue and see if we can implement a fix for it in our future updates.
pinchies, User (Posts: 3)
Feb 21, 2021 11:44:38 pm EST
App crash while sitting idle in the background. Mac OS Mojave, 10.14.6 (18G8012)
Process:               viewer [57479]
Path:                  /Applications/viewer.app/Contents/MacOS/viewer
Identifier:            com.remoteutilities.viewer
Version:               0
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           viewer [57479]
User ID:               501
Date/Time:             2021-02-22 15:34:34.001 +1100
OS Version:            Mac OS X 10.14.6 (18G8012)
Report Version:        12
Anonymous UUID:        F0D2725A-8534-1367-D9E4-9A242C9CD718
Sleep/Wake UUID:       ADD49793-99DB-4E3C-B9AE-C947E02461BA
Time Awake Since Boot: 160000 seconds
Time Since Wake:       5000 seconds
System Integrity Protection: disabled
Crashed Thread:        3  TCheckIDStateThread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000200
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Segmentation fault: 11
Termination Reason:    Namespace SIGNAL, Code 0xb
Terminating Process:   exc handler [57479]
VM Regions Near 0x200:
   __TEXT                 000000010a6e7000-000000010b6fb000 [ 16.1M] r-x/r-x SM=COW /Applications/viewer.app/Contents/MacOS/viewer
Thread 0:: Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib         0x00007fff7dbd521a mach_msg_trap + 10
1   libsystem_kernel.dylib         0x00007fff7dbd5768 mach_msg + 60
2   com.apple.CoreFoundation       0x00007fff51abc7b2 __CFRunLoopServiceMachPort + 328
3   com.apple.CoreFoundation       0x00007fff51abbd20 __CFRunLoopRun + 1612
4   com.apple.CoreFoundation       0x00007fff51abb482 CFRunLoopRunSpecific + 455
5   com.apple.HIToolbox           0x00007fff50d1a1ab RunCurrentEventLoopInMode + 292
6   com.apple.HIToolbox           0x00007fff50d19ee5 ReceiveNextEventCommon + 603
7   com.apple.HIToolbox           0x00007fff50d19c76 _BlockUntilNextEventMatchingListInModeWithFilter + 64
8   com.apple.AppKit               0x00007fff4f0b177d _DPSNextEvent + 1135
9   com.apple.AppKit               0x00007fff4f0b046b -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361
10  com.apple.AppKit               0x00007fff4f0aa588 -[NSApplication run] + 699
11  com.remoteutilities.viewer     0x000000010a90e7d4 QCocoaEventDispatcher::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 2516
12  com.remoteutilities.viewer     0x000000010b28f3f7 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 471
13  com.remoteutilities.viewer     0x000000010b292f62 QCoreApplication::exec() + 130
14  com.remoteutilities.viewer     0x000000010a733438 main + 136
15  libdyld.dylib                 0x00007fff7daa03d5 start + 1
Thread 1:: com.apple.NSEventThread
5   com.apple.AppKit               0x00007fff4f0b94a2 _NSEventThread + 175
6   libsystem_pthread.dylib       0x00007fff7dc942eb _pthread_body + 126
7   libsystem_pthread.dylib       0x00007fff7dc97249 _pthread_start + 66
8   libsystem_pthread.dylib       0x00007fff7dc9340d thread_start + 13
Thread 2:
0   libsystem_pthread.dylib       0x00007fff7dc933f0 start_wqthread + 0
Thread 3 Crashed:: TCheckIDStateThread
0   com.remoteutilities.viewer     0x000000010b12eea1 QMutex::lock() + 49
1   com.remoteutilities.viewer     0x000000010b12d916 QThread::isInterruptionRequested() const + 38
2   com.remoteutilities.viewer     0x000000010a702e3f TTCPSocket::writeData(QByteArray) + 31
3   com.remoteutilities.viewer     0x000000010a70310e TTCPSocket::writeInt64(long long, bool) + 78
4   com.remoteutilities.viewer     0x000000010a71302c TCheckIDStateThread::run() + 2060
5   com.remoteutilities.viewer     0x000000010b12e229 QThreadPrivate::start(void*) + 329
Thread 4:: TTCPSocket
0   libsystem_kernel.dylib         0x00007fff7dbdd36a poll + 10
1   com.remoteutilities.viewer     0x000000010b2d0cde qt_safe_poll(pollfd*, unsigned int, timespec const*) + 94
2   com.remoteutilities.viewer     0x000000010b2d21a6 QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 790
3   com.remoteutilities.viewer     0x000000010b28f3f7 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 471
4   com.remoteutilities.viewer     0x000000010b12d603 QThread::exec() + 131
5   com.remoteutilities.viewer     0x000000010a702496 TTCPSocket::run() + 518
6   com.remoteutilities.viewer     0x000000010b12e229 QThreadPrivate::start(void*) + 329
7   libsystem_pthread.dylib       0x00007fff7dc942eb _pthread_body + 126
8   libsystem_pthread.dylib       0x00007fff7dc97249 _pthread_start + 66
9   libsystem_pthread.dylib       0x00007fff7dc9340d thread_start + 13
Thread 5:: Thread (pooled)
0   libsystem_kernel.dylib         0x00007fff7dbd8866 __psynch_cvwait + 10
1   libsystem_pthread.dylib       0x00007fff7dc9756e _pthread_cond_wait + 722
2   com.remoteutilities.viewer     0x000000010b134b70 QWaitConditionPrivate::wait_relative(QDeadlineTimer) + 272
3   com.remoteutilities.viewer     0x000000010b1349ee QWaitConditionPrivate::wait(QDeadlineTimer) + 94
4   com.remoteutilities.viewer     0x000000010b134963 QWaitCondition::wait(QMutex*, QDeadlineTimer) + 83
5   com.remoteutilities.viewer     0x000000010b131e5d QThreadPoolThread::run() + 621
Thread 3 crashed with X86 Thread State (64-bit):
 rax: 0x0000000000000200  rbx: 0x0000000000000200  rcx: 0x0000000000000001  rdx: 0x0000000000000000
 rdi: 0x0000600003ff78f8  rsi: 0x0000700000b3ec40  rbp: 0x0000700000b3eac0  rsp: 0x0000700000b3eab0
  r8: 0x000000000000049f   r9: 0x00000000000007fb  r10: 0x00000000000038a0  r11: 0xfffff00003471e38
 r12: 0x00006000033e8040  r13: 0x0000600001288f00  r14: 0x0000700000b3ec40  r15: 0x0000600003ff78f8
 rip: 0x000000010b12eea1  rfl: 0x0000000000010216  cr2: 0x0000000000000200
Logical CPU:     5
Error Code:      0x00000004
Trap Number:     14
Binary Images:
      0x10a6e7000 -        0x10b6fa0b7 +com.remoteutilities.viewer (0) <5DF5D685-3BFB-3457-9BEE-5D9B1703A5AD> /Applications/viewer.app/Contents/MacOS/viewer
      0x10e1dd000 -        0x10e1e0047  libobjc-trampolines.dylib (756.2) <5795A048-3940-3801-90CE-33D1B1AF81F4> /usr/lib/libobjc-trampolines.dylib
      0x116b4d000 -        0x116bb770f  dyld (655.1.1) <EA5BF483-08FB-31C9-B31E-C0D0FD94FE89> /usr/lib/dyld
   0x7fff461e1000 -     0x7fff4653afff  com.apple.RawCamera.bundle (8.15.0 - 1031.4.4) <AB6E8A8F-0BFE-37EE-A135-44ABA4FCB559> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
   0x7fff4653d000 -     0x7fff46649fff  com.apple.AMDMTLBronzeDriver (2.11.23 - 2.1.1) <69902D3A-0267-3D14-9820-D65016305FCC> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
   0x7fff4a1bd000 -     0x7fff4a24eff7  com.apple.driver.AppleIntelHD5000GraphicsMTLDriver (12.10.25 - 12.1.0) <5AC043A7-7433-39BB-A8CB-1A5F0E562684> /System/Library/Extensions/AppleIntelHD5000GraphicsMTLDriver­.bundle/Contents/MacOS/AppleIntelHD5000GraphicsMTLDriver
   0x7fff4dab4000 -     0x7fff4dab8fff  com.apple.agl (3.3.2 - AGL-3.3.2) <7E700D5B-3653-30DD-A450-BDA02E23C0A1> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
   0x7fff4de63000 -     0x7fff4de63fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <762942CB-CFC9-3A0C-9645-A56523A06426> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
   0x7fff4de64000 -     0x7fff4de7aff7  libCGInterfaces.dylib (506.22) <1B6C92D9-F4B8-37BA-9635-94C4A56098CE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
   0x7fff4de7b000 -     0x7fff4e514fef  com.apple.vImage (8.1 - ???) <53FA3611-894E-3158-A654-FBD2F70998FE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
   0x7fff4e515000 -     0x7fff4e78eff3  libBLAS.dylib (1243.200.4) <417CA0FC-B6CB-3FB3-ACBC-8914E3F62D20> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
   0x7fff4e78f000 -     0x7fff4e801ffb  libBNNS.dylib (38.250.1) <538D12A2-9B9D-3E22-9896-F90F6E69C06E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
   0x7fff4e802000 -     0x7fff4ebabff3  libLAPACK.dylib (1243.200.4) <92175DF4-863A-3780-909A-A3E5C410F2E9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
   0x7fff4ebac000 -     0x7fff4ebc1feb  libLinearAlgebra.dylib (1243.200.4) <CB671EE6-DEA1-391C-9B2B-AA09A46B4D7A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
   0x7fff4ebc2000 -     0x7fff4ebc7ff3  libQuadrature.dylib (3.200.2) <1BAE7E22-2862-379F-B334-A3756067730F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
   0x7fff4ebc8000 -     0x7fff4ec44ff3  libSparse.dylib (79.200.5) <E78B33D3-672A-3C53-B512-D3DDB2E9AC8D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
   0x7fff4ec45000 -     0x7fff4ec58fe3  libSparseBLAS.dylib (1243.200.4) <E9243341-DB77-37C1-97C5-3DFA00DD70FA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
   0x7fff4ec59000 -     0x7fff4ee40ff7  libvDSP.dylib (671.250.4) <7B110627-A9C1-3FB7-A077-0C7741BA25D8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
   0x7fff4ee41000 -     0x7fff4eef4ff7  libvMisc.dylib (671.250.4) <D5BA4812-BFFC-3CD0-B382-905CD8555DA6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
   0x7fff4eef5000 -     0x7fff4eef5fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <74288115-EF61-30B6-843F-0593B31D4929> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
   0x7fff4f097000 -     0x7fff4fe4cffb  com.apple.AppKit (6.9 - 1671.60.109) <F3BB6BCD-F2DF-36E7-8F20-FEC419671841> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
   0x7fff4fe9e000 -     0x7fff4fe9efff  com.apple.ApplicationServices (50.1 - 50.1) <7BDB78C7-9021-3B29-823A-1FFDB9F79602> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
   0x7fff4fe9f000 -     0x7fff4ff0afff  com.apple.ApplicationServices.ATS (377 - 453.11.2.2) <A258DA73-114B-3102-A056-4AAAD3CEB9DD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
   0x7fff4ffa3000 -     0x7fff500baff7  libFontParser.dylib (228.6.2.10) <B0B7AF1F-2342-3A95-A7E6-629FC032D4B1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
   0x7fff500bb000 -     0x7fff500fdfff  libFontRegistry.dylib (228.12.2.4) <6DDE44EC-FF6B-3893-9209-45E0955ABDD5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
   0x7fff50157000 -     0x7fff50189fff  libTrueTypeScaler.dylib (228.6.2.10) <5FE48A9A-8329-3B0D-9A99-DEAC708F8334> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
   0x7fff501ee000 -     0x7fff501f2ff3  com.apple.ColorSyncLegacy (4.13.0 - 1) <E8E9342C-47EB-359D-A373-554AC19B174A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
   0x7fff5028d000 -     0x7fff502dfff7  com.apple.HIServices (1.22 - 628) <2BE461FF-80B9-30D3-A574-AED5724B1C1B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
   0x7fff502e0000 -     0x7fff502effff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <F5617A2A-FEA6-3832-B5BA-C2111B98786F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
   0x7fff502f0000 -     0x7fff50339ff7  com.apple.print.framework.PrintCore (14.7 - 503.8) <E1D0FCBC-155E-372E-A90F-4A20B94FC114> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
   0x7fff5033a000 -     0x7fff50373ff7  com.apple.QD (3.12 - 407.2) <28C7D39F-59C9-3314-BECC-67045487229C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
   0x7fff50374000 -     0x7fff50380fff  com.apple.speech.synthesis.framework (8.1.3 - 8.1.3) <5E7B9BD4-122B-3012-A044-3259C97E7509> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
   0x7fff50381000 -     0x7fff505f8fff  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <32487CB2-246B-3B80-8F60-D65DFC367DDC> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
   0x7fff505fa000 -     0x7fff505fafff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <B489CFDA-DEF3-38F5-A815-23EC30B8DA03> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
   0x7fff50953000 -     0x7fff50cf5fff  com.apple.CFNetwork (978.5 - 978.5) <06BB192E-0302-3AE9-B229-A9B15AD4CBF4> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
   0x7fff50d0a000 -     0x7fff50d0afff  com.apple.Carbon (158 - 158) <B955D7C0-ACA6-33EB-9527-1598288532A6> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
   0x7fff50d0b000 -     0x7fff50d0effb  com.apple.CommonPanels (1.2.6 - 98) <1CD6D56D-8EC7-3528-8CBC-FC69533519B5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
   0x7fff50d0f000 -     0x7fff51006fff  com.apple.HIToolbox (2.1.1 - 918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
   0x7fff51007000 -     0x7fff5100aff3  com.apple.help (1.3.8 - 66) <A08517EB-8958-36C9-AEE0-1A8FEEACBE3F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
   0x7fff5100b000 -     0x7fff51010ff7  com.apple.ImageCapture (9.0 - 1534.2) <DB063E87-ED8F-3E4E-A7E2-A6B45FA73EF7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
   0x7fff51011000 -     0x7fff510a6ff3  com.apple.ink.framework (10.9 - 225) <7C7E9483-2E91-3DD3-B1E0-C238F42CA0DD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
   0x7fff510a7000 -     0x7fff510bfff7  com.apple.openscripting (1.7 - 179.1) <9B8C1ECC-5864-3E21-9149-863E884EA25C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
   0x7fff510df000 -     0x7fff510e0ff7  com.apple.print.framework.Print (14.2 - 267.4) <A7A9D2A0-D4E0-35EF-A0F7-50521F707C33> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
   0x7fff510e1000 -     0x7fff510e3ff7  com.apple.securityhi (9.0 - 55006) <05717F77-7A7B-37E6-AB3E-03F063E9095B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
   0x7fff510e4000 -     0x7fff510eaff7  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <3CC050FB-EBCB-3087-8EA5-F378C8F99217> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
   0x7fff5121a000 -     0x7fff51369ff7  com.apple.ColorSync (4.13.0 - 3345.6) <356BA478-76DE-3087-86BE-5E884276AB83> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
   0x7fff514f5000 -     0x7fff5157bfff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <E6E4A58D-9BAE-30B1-856E-E1332B98E9ED> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
   0x7fff515df000 -     0x7fff51609ffb  com.apple.CoreBluetooth (1.0 - 1) <4F2DDEF0-1F92-384B-8CDA-4958725D0A8E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
   0x7fff5160a000 -     0x7fff5198ffef  com.apple.CoreData (120 - 866.6) <132CB39B-8D58-30FA-B8AD-49BFFF34B293> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
   0x7fff51990000 -     0x7fff51a80ff7  com.apple.CoreDisplay (101.3 - 110.18) <6DD41271-E145-3E99-9D49-7CC8AC1C65B6> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
   0x7fff51a81000 -     0x7fff51ec6fff  com.apple.CoreFoundation (6.9 - 1575.401) <4D6EA727-F7B9-398A-9B0B-4A30802E49BD> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
   0x7fff51ec8000 -     0x7fff52558fe7  com.apple.CoreGraphics (2.0 - 1265.11) <71E7056D-6AA5-324A-A5B8-9CD35772D87B> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
   0x7fff5255a000 -     0x7fff5287afff  com.apple.CoreImage (14.4.0 - 750.0.140) <11026E39-D2FF-3CF6-8ACE-7BA293F9853E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
   0x7fff52b77000 -     0x7fff52c7bfff  com.apple.CoreMedia (1.0 - 2290.14) <2C7A5348-7F19-3E28-97E4-6065A64B1DC9> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
   0x7fff52cd8000 -     0x7fff52cd8fff  com.apple.CoreServices (946 - 946) <8423F2AB-74CB-3BBD-A66E-ED93DE2363C2> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
   0x7fff52cd9000 -     0x7fff52d55ff7  com.apple.AE (773 - 773) <55AE7C9E-27C3-30E9-A047-3B92A6FD53B4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
   0x7fff52d56000 -     0x7fff5302dfff  com.apple.CoreServices.CarbonCore (1178.33 - 1178.33) <CB87F0C7-2CD6-3983-8E32-B6A2EC925352> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
   0x7fff5302e000 -     0x7fff53076ff7  com.apple.DictionaryServices (1.2 - 284.16.4) <746EB200-DC51-30AE-9CBC-608A7B4CC8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
   0x7fff53077000 -     0x7fff5307fffb  com.apple.CoreServices.FSEvents (1239.200.13 - 1239.200.13) <5913F08D-4AA2-3200-B998-012E6A19A66D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
   0x7fff53080000 -     0x7fff53231ff7  com.apple.LaunchServices (946 - 946) <A0C91634-9410-38E8-BC11-7A5A369E6BA5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
   0x7fff53232000 -     0x7fff532d0ff7  com.apple.Metadata (10.7.0 - 1191.58) <89DA10B4-5695-3FD9-A920-C34C33957868> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
   0x7fff532d1000 -     0x7fff5331bff7  com.apple.CoreServices.OSServices (946 - 946) <20C4EEF8-D5AC-39A0-9B4A-78F88E3EFBCC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
   0x7fff5331c000 -     0x7fff53383ff7  com.apple.SearchKit (1.4.0 - 1.4.0) <DA08AA6F-A6F1-36C0-87F4-E26294E51A3A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
   0x7fff53384000 -     0x7fff533a5ff3  com.apple.coreservices.SharedFileList (71.28 - 71.28) <487A8464-729E-305A-B5D1-E3FE8EB9CFC5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
   0x7fff536b0000 -     0x7fff53812ff7  com.apple.CoreText (352.0 - 584.26.3.6) <47B18B6F-C53C-357A-8EBA-A2CD340018E6> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
   0x7fff53813000 -     0x7fff53853ff3  com.apple.CoreVideo (1.8 - 281.4) <10CF8E52-07E3-382B-8091-2CEEEFFA69B4> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
   0x7fff53854000 -     0x7fff538e3fff  com.apple.framework.CoreWLAN (13.0 - 1375.2) <A476486C-B863-3941-BAE6-A78BDFED4A3B> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
   0x7fff53b3a000 -     0x7fff53b3fffb  com.apple.DiskArbitration (2.7 - 2.7) <A31C207C-8255-3E93-9DD7-D80C4B179050> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
   0x7fff53d06000 -     0x7fff540b3ffb  com.apple.Foundation (6.9 - 1575.401) <546CCD67-0069-369A-8E6A-37FB5DD64AA1> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
   0x7fff54122000 -     0x7fff54151ffb  com.apple.GSS (4.0 - 2.0) <E2B90D08-3857-3155-9FCC-07D778988EC9> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
   0x7fff54251000 -     0x7fff5435bfff  com.apple.Bluetooth (6.0.14 - 6.0.14d12) <0904E4FC-DE05-3B78-BD49-832A5AC2967D> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
   0x7fff543be000 -     0x7fff5444dfff  com.apple.framework.IOKit (2.0.2 - 1483.260.5) <6D560570-9AEB-3046-96B7-12AC1D145C3D> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
   0x7fff5444f000 -     0x7fff5445effb  com.apple.IOSurface (255.6.1 - 255.6.1) <85F85EBB-EA59-3A8B-B3EB-7C20F3CC77AE> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
   0x7fff544b2000 -     0x7fff5463ffe7  com.apple.ImageIO.framework (3.3.0 - 1850.2.11) <5F5F7C36-2A20-3CFE-ACAC-53633B0F2F0A> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
   0x7fff54640000 -     0x7fff54644ffb  libGIF.dylib (1850.2.12) <060E927C-DFA7-33A7-98E3-F9699D734A8E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
   0x7fff54645000 -     0x7fff54721ff7  libJP2.dylib (1850.2.12) <CEC4FF68-7522-3430-B03D-37648FEB450E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
   0x7fff54722000 -     0x7fff54747feb  libJPEG.dylib (1850.2.12) <F7A6A6EC-24B6-3C45-813F-B2FFA3980B49> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
   0x7fff54a1d000 -     0x7fff54a43feb  libPng.dylib (1850.2.12) <B816B90B-2454-31D8-AD34-1489B6350C70> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
   0x7fff54a44000 -     0x7fff54a46ffb  libRadiance.dylib (1850.2.12) <1A67ED5D-00BC-301D-8515-CEDFFE994F2B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
   0x7fff54a47000 -     0x7fff54a94ff3  libTIFF.dylib (1850.2.12) <3FB9D8DC-1D7B-324C-ADE6-DDC794FD2B43> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
   0x7fff55c07000 -     0x7fff55c20fff  com.apple.Kerberos (3.0 - 1) <DB1E0679-37E1-3B93-9789-32F63D660C3B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
   0x7fff55eda000 -     0x7fff55ee4fff  com.apple.MediaAccessibility (1.0 - 114.4) <76C449C5-DB45-3D7F-BFAD-3DACEF15DA21> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
   0x7fff55f94000 -     0x7fff5663afff  com.apple.MediaToolbox (1.0 - 2290.14) <927F9E24-32DB-33F9-9866-4DD8092A51F4> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
   0x7fff5663c000 -     0x7fff566e4ff7  com.apple.Metal (162.2 - 162.2) <B65C71BF-D40E-3BB3-940C-117DDD203551> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
   0x7fff56700000 -     0x7fff5671fff7  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <44CE8362-E972-3697-AD6F-15BC863BAEB8> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
   0x7fff56720000 -     0x7fff5679cfe7  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <EE8440DA-66DF-3923-ABBC-E0543211C069> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
   0x7fff5679d000 -     0x7fff567c4fff  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <E64450DF-2B96-331E-B7F4-666E00571C70> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
   0x7fff567c5000 -     0x7fff568f0ff7  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <F2CF26B6-73F1-3644-8FE9-CDB9B2C4501F> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
   0x7fff568f1000 -     0x7fff5690bfff  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <B33A35C3-0393-366B-ACFB-F4BB6A5F7B4A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
   0x7fff5690c000 -     0x7fff5690dff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <69F14BCF-C5C5-3BF8-9C31-8F87D2D6130A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
   0x7fff57711000 -     0x7fff5771dff7  com.apple.NetFS (6.0 - 4.0) <1C8237D6-731D-3E32-8BD5-B92A33D08A30> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
   0x7fff5a1bb000 -     0x7fff5a212ff7  com.apple.opencl (2.15.3 - 2.15.3) <2F6B796C-901C-33AF-8B12-F3522DA05218> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
   0x7fff5a213000 -     0x7fff5a22eff7  com.apple.CFOpenDirectory (10.14 - 207.200.4) <F03D84EB-49B2-3A00-9127-B9A269824026> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
   0x7fff5a22f000 -     0x7fff5a23affb  com.apple.OpenDirectory (10.14 - 207.200.4) <A8020CEE-5B78-3581-A735-EA2833683F31> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
   0x7fff5ab8a000 -     0x7fff5ab8cfff  libCVMSPluginSupport.dylib (17.7.3) <700B3323-3404-3848-91D2-99EFC7E2634A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
   0x7fff5ab8d000 -     0x7fff5ab92ff3  libCoreFSCache.dylib (166.5) <5BC99EE7-7FFD-3F30-9AEE-EEDC25067AC4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
   0x7fff5ab93000 -     0x7fff5ab97fff  libCoreVMClient.dylib (166.5) <B8FA5858-8185-3992-AD3B-A81AF08C3CDD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
   0x7fff5ab98000 -     0x7fff5aba0ff7  libGFXShared.dylib (17.7.3) <26BA051E-1113-3022-A46A-1F69E7CFA787> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
   0x7fff5aba1000 -     0x7fff5abacfff  libGL.dylib (17.7.3) <16C56C55-327F-395F-810C-C360F7DE9063> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
   0x7fff5abad000 -     0x7fff5abe7fef  libGLImage.dylib (17.7.3) <F68F1268-5AD1-3D2E-A255-0BD442A24F4D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
   0x7fff5ad5b000 -     0x7fff5ad99fff  libGLU.dylib (17.7.3) <D83871DF-B7DD-3DFD-8D5C-0BA359AC1BF2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
   0x7fff5b736000 -     0x7fff5b745ffb  com.apple.opengl (17.7.3 - 17.7.3) <62E4CB29-51CA-387E-90BF-F58213D56D62> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
   0x7fff5c54f000 -     0x7fff5c7a6ff7  com.apple.QuartzCore (1.11 - 701.14) <B37B1291-4977-34D2-B3F0-509FB3DB5090> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
   0x7fff5cfde000 -     0x7fff5d2deff7  com.apple.security (7.0 - 58286.270.10) <990FF42E-0726-318F-94ED-A8FDF7F41402> /System/Library/Frameworks/Security.framework/Versions/A/Security
   0x7fff5d2df000 -     0x7fff5d36bfff  com.apple.securityfoundation (6.0 - 55185.260.1) <964F1F81-D8F1-3952-8137-EF21CDD3A7A6> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
   0x7fff5d39d000 -     0x7fff5d3a1fff  com.apple.xpc.ServiceManagement (1.0 - 1) <5055F807-1DD4-3F97-A2A6-4537F51A5736> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
   0x7fff5d73a000 -     0x7fff5d7a7fff  com.apple.SystemConfiguration (1.17 - 1.17) <30C8327F-3EFF-3520-9C50-016F8B6B954F> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
   0x7fff5da06000 -     0x7fff5dd67fff  com.apple.VideoToolbox (1.0 - 2290.14) <30C690CF-8935-39E8-B343-ADB009C84FC5> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
   0x7fff609e3000 -     0x7fff60a88fff  com.apple.APFS (1.0 - 1) <06284DE8-5883-39F8-B04D-0D5EA74D12ED> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
   0x7fff6149d000 -     0x7fff6149eff7  com.apple.AggregateDictionary (1.0 - 1) <A6AF8AC4-1F25-37C4-9157-A02E9C200926> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
   0x7fff61aa1000 -     0x7fff61acdff7  com.apple.framework.Apple80211 (13.0 - 1380.2) <E4D12303-8B12-303C-91E2-3B40F60832BA> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
   0x7fff61bf5000 -     0x7fff61c04fc7  com.apple.AppleFSCompression (96.200.3 - 1.0) <3CF60CE8-976E-3CB8-959D-DD0948C1C2DE> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
   0x7fff61d00000 -     0x7fff61d0bfff  com.apple.AppleIDAuthSupport (1.0 - 1) <2E9D1398-DBE6-328B-ADDA-20FA5FAD7405> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
   0x7fff61d4c000 -     0x7fff61d95ff3  com.apple.AppleJPEG (1.0 - 1) <4C1F426B-7D77-3980-9633-7DBD8C666B9A> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
   0x7fff61fe9000 -     0x7fff6200bfff  com.apple.applesauce (1.0 - ???) <F49107C7-3C51-3024-8EF1-C57643BE4F3B> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
   0x7fff620cf000 -     0x7fff6211fff7  com.apple.AppleVAFramework (5.1.4 - 5.1.4) <FB127E63-853B-3F00-BE2A-12B4BF6FED33> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
   0x7fff6216a000 -     0x7fff6217effb  com.apple.AssertionServices (1.0 - 1) <456E507A-4561-3628-9FBE-173ACE7429D8> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
   0x7fff6254d000 -     0x7fff62639ff7  com.apple.AuthKit (1.0 - 1) <2765ABE9-54F2-3E45-8A93-1261E251B90D> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
   0x7fff627fb000 -     0x7fff62803fff  com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <2A396FC0-7B79-3088-9A82-FB93C1181A57> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
   0x7fff62804000 -     0x7fff62899fff  com.apple.backup.framework (1.10.7 - ???) <5243C2BC-0159-3DBB-9FAB-22EA01E58052> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
   0x7fff6289a000 -     0x7fff62907ff3  com.apple.BaseBoard (360.28 - 360.28) <68FA8044-F3CD-3BC6-9DAB-27DACF52BFC0> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
   0x7fff64574000 -     0x7fff6457dffb  com.apple.CommonAuth (4.0 - 2.0) <93335CB6-ABEB-3EC7-A040-8A667F40D5F3> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
   0x7fff64a16000 -     0x7fff64df9fef  com.apple.CoreAUC (274.0.0 - 274.0.0) <C71F1581-E73B-3DA0-958B-E912C3FB3F23> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
   0x7fff64dfa000 -     0x7fff64e28ff7  com.apple.CoreAVCHD (6.0.0 - 6000.4.1) <A04A99B8-DAC5-36FC-BAC7-7431600C1F89> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
   0x7fff65256000 -     0x7fff65267ff7  com.apple.CoreEmoji (1.0 - 69.19.9) <228457B3-E191-356E-9A5B-3C0438D05FBA> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
   0x7fff65811000 -     0x7fff65877ff7  com.apple.CoreNLP (1.0 - 130.15.22) <27877820-17D0-3B02-8557-4014E876CCC7> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
   0x7fff65b24000 -     0x7fff65b2cff7  com.apple.CorePhoneNumbers (1.0 - 1) <11F97C7E-C183-305F-8E6C-9B374F50E26B> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
   0x7fff65ca8000 -     0x7fff65cd9ff3  com.apple.CoreServicesInternal (358 - 358) <DD6EF60D-048F-3186-83DA-EB191EDF48AE> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
   0x7fff660a0000 -     0x7fff66124fff  com.apple.CoreSymbolication (10.2 - 64490.25.1) <28B2FF2D-3FDE-3A20-B343-341E5BD4E22F> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
   0x7fff661b4000 -     0x7fff662dfff7  com.apple.coreui (2.1 - 499.10) <A80F4B09-F940-346F-A9DF-4EFADD9220A8> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
   0x7fff662e0000 -     0x7fff66480fff  com.apple.CoreUtils (5.9 - 590.16) <BF9A990D-24C0-3633-A753-F19F4DFCA663> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
   0x7fff664d4000 -     0x7fff66537ff7  com.apple.framework.CoreWiFi (13.0 - 1375.2) <7E9CC352-BB06-3C97-A51F-6A35F09EBA16> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
   0x7fff66538000 -     0x7fff66549ff3  com.apple.CrashReporterSupport (10.13 - 938.29) <8A66F5D5-87D1-31C9-BEAE-86E0735F4E92> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
   0x7fff665d9000 -     0x7fff665e8fff  com.apple.framework.DFRFoundation (1.0 - 211.1) <E3F02F2A-2059-39CC-85DA-969676EB88EB> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
   0x7fff665e9000 -     0x7fff665edff7  com.apple.DSExternalDisplay (3.1 - 380) <787B9748-B120-3453-B8FE-61D9E363A9E0> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
   0x7fff6666e000 -     0x7fff666e3ffb  com.apple.datadetectorscore (7.0 - 590.27) <06FB1A07-7AE6-3ADD-8E7E-41955FAB38E8> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
   0x7fff6672f000 -     0x7fff6676cff7  com.apple.DebugSymbols (190 - 190) <6F4FAACA-E06B-38AD-A0C2-14EA5408A231> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
   0x7fff6676d000 -     0x7fff668a8ff7  com.apple.desktopservices (1.13.6 - ???) <7536F3F3-90F1-3D1C-9249-91B809FE5328> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
   0x7fff677ef000 -     0x7fff67c0afff  com.apple.vision.FaceCore (3.3.4 - 3.3.4) <A576E2DA-BF6F-3B18-8FEB-324E5C5FA9BD> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
   0x7fff6b4be000 -     0x7fff6b4bffff  libmetal_timestamp.dylib (902.3.2) <05389463-AF2E-33E2-A14F-1416E4A30835> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib
   0x7fff6cb5f000 -     0x7fff6cb64fff  com.apple.GPUWrangler (3.50.16 - 3.50.16) <1156CF8C-729B-3173-B3CC-00BB17156BCC> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
   0x7fff6d970000 -     0x7fff6d97ffff  com.apple.GraphVisualizer (1.0 - 5) <48D020B7-5938-3FAE-B468-E291AEE2C06F> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
   0x7fff6dae5000 -     0x7fff6db59ffb  com.apple.Heimdal (4.0 - 2.0) <D97FCF19-EAD6-3E2F-BE88-F817E45CAE96> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
   0x7fff6ee5a000 -     0x7fff6ee63fff  com.apple.IOAccelMemoryInfo (1.0 - 1) <32F6778F-3EB5-36A3-8AF8-55B37A44AC0C> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
   0x7fff6ee64000 -     0x7fff6ee6bffb  com.apple.IOAccelerator (404.15 - 404.15) <06D2C96E-1CF5-3199-A234-9033934D78BF> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
   0x7fff6ee6f000 -     0x7fff6ee87fff  com.apple.IOPresentment (1.0 - 42.6) <D2BA3A78-21C6-37B8-9F8F-9EC0F30F953F> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
   0x7fff6f22f000 -     0x7fff6f25cff7  com.apple.IconServices (379 - 379) <7BAD562D-4FA3-3E11-863C-1EEBE2406D2C> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
   0x7fff6f4ef000 -     0x7fff6f501ff3  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <D5DDE47A-E922-3166-BD7F-E7C3DF360DD9> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
   0x7fff6f51c000 -     0x7fff6f5f7ff7  com.apple.LanguageModeling (1.0 - 159.15.15) <3DE3CE61-542B-37B7-883E-4B9717CAC65F> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
   0x7fff6f5f8000 -     0x7fff6f634ff7  com.apple.Lexicon-framework (1.0 - 33.15.10) <4B5E843E-2809-3E70-9560-9254E2656419> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
   0x7fff6f63b000 -     0x7fff6f640fff  com.apple.LinguisticData (1.0 - 238.25) <F529B961-098C-3E4C-A3E9-9DA9BFA1B3F0> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
   0x7fff6fe5f000 -     0x7fff6fe62fff  com.apple.Mangrove (1.0 - 25) <537A5B2E-4C30-3CFD-8BDC-79F9A04AC327> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
   0x7fff70336000 -     0x7fff7035eff7  com.apple.spotlight.metadata.utilities (1.0 - 1191.58) <23E8580B-19C0-3E4F-A9FE-368DA80EAA6F> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
   0x7fff7035f000 -     0x7fff703ecff7  com.apple.gpusw.MetalTools (1.0 - 1) <9B542958-6363-3041-A265-EC7AC7BD7A43> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
   0x7fff70403000 -     0x7fff7041cffb  com.apple.MobileAssets (1.0 - 437.250.3) <8BE5B3A0-8F3A-3FAE-9AFF-32836300183C> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
   0x7fff705e8000 -     0x7fff70603ffb  com.apple.MobileKeyBag (2.0 - 1.0) <39337CBB-1D39-3DDC-A998-591194C76523> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
   0x7fff7068c000 -     0x7fff706b6ffb  com.apple.MultitouchSupport.framework (2450.1 - 2450.1) <42A23EC9-64A7-31C7-BF33-DF4412ED8A3F> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
   0x7fff708f2000 -     0x7fff708fcfff  com.apple.NetAuth (6.2 - 6.2) <0D01BBE5-0269-310D-B148-D19DAE143DEB> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
   0x7fff7115e000 -     0x7fff711afff3  com.apple.OTSVG (1.0 - ???) <CB2F1DBE-0313-30CB-A95F-2FE75E0A089E> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
   0x7fff72348000 -     0x7fff72357ff7  com.apple.PerformanceAnalysis (1.218.2 - 218.2) <65F3DB3E-6D4E-33A0-B510-EF768D323DAB> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
   0x7fff741e9000 -     0x7fff74207ff7  com.apple.ProtocolBuffer (1 - 263.2) <907D6C95-D050-31DE-99CA-16A5135BC6F9> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
   0x7fff7439f000 -     0x7fff743effff  com.apple.ROCKit (27.6 - 27.6) <756C2253-E8B1-3C48-9945-DE8D6AD24DE2> /System/Library/PrivateFrameworks/ROCKit.framework/Versions/A/ROCKit
   0x7fff74549000 -     0x7fff7456bfff  com.apple.RemoteViewServices (2.0 - 128) <8FB0E4EB-DCBB-32E6-94C6-AA9BA9EE4CAC> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
   0x7fff75d75000 -     0x7fff75e93fff  com.apple.Sharing (1288.62.5 - 1288.62.5) <BB647030-839A-3271-B205-D4325346DD3B> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
   0x7fff76ca8000 -     0x7fff76f57fff  com.apple.SkyLight (1.600.0 - 340.55) <1F737945-E242-3F03-A7D6-1A5955AB1298> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
   0x7fff776fb000 -     0x7fff77707fff  com.apple.SpeechRecognitionCore (5.0.21 - 5.0.21) <7A6A67DB-C813-328E-AAFB-D267A5B50B3D> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
   0x7fff77da6000 -     0x7fff77de2ff3  com.apple.StreamingZip (1.0 - 1) <046FAD5C-E0C5-3013-B1FE-24C018A0DDCF> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
   0x7fff77e58000 -     0x7fff77ee3fc7  com.apple.Symbolication (10.2 - 64490.38.1) <9FDCC98D-5B32-35AD-A9BF-94DF2B78507F> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
   0x7fff783c9000 -     0x7fff783d5ffb  com.apple.TCC (1.0 - 1) <E3691073-7284-35E4-94F3-16587A7F380F> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
   0x7fff7863b000 -     0x7fff78703ff3  com.apple.TextureIO (3.8.4 - 3.8.1) <7CEAC05A-D283-3D5A-B1E3-C849285FA0BF> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
   0x7fff787c0000 -     0x7fff78978ffb  com.apple.UIFoundation (1.0 - 551.5) <A0FDC3A4-45C6-3C87-B77F-7DC394374C08> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
   0x7fff795f4000 -     0x7fff796cdfff  com.apple.ViewBridge (406 - 406) <3CC6AE31-2CD7-30CA-982C-47EF242EFA30> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
   0x7fff79ea5000 -     0x7fff79ea8fff  com.apple.dt.XCTTargetBootstrap (1.0 - 14490.66) <7AE3457F-AF40-3508-93FB-1D9E31EB1C9D> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
   0x7fff7a2a9000 -     0x7fff7a2abffb  com.apple.loginsupport (1.0 - 1) <3F8D6334-BCD6-36C1-BA20-CC8503A84375> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
   0x7fff7a575000 -     0x7fff7a5a9fff  libCRFSuite.dylib (41.15.4) <406DAC06-0C77-3F90-878B-4D38F11F0256> /usr/lib/libCRFSuite.dylib
   0x7fff7a5ac000 -     0x7fff7a5b6ff7  libChineseTokenizer.dylib (28.15.3) <9B7F6109-3A5D-3641-9A7E-31D2239D73EE> /usr/lib/libChineseTokenizer.dylib
   0x7fff7a644000 -     0x7fff7a645ffb  libDiagnosticMessagesClient.dylib (107) <A14D0819-0970-34CD-8680-80E4D7FE8C2C> /usr/lib/libDiagnosticMessagesClient.dylib
   0x7fff7a67c000 -     0x7fff7a8d3ff3  libFosl_dynamic.dylib (18.3.4) <1B5DD4E2-8AE0-315E-829E-D5BFCD264EA8> /usr/lib/libFosl_dynamic.dylib
   0x7fff7a924000 -     0x7fff7a943fff  libMobileGestalt.dylib (645.270.1) <99A06C8A-97D6-383D-862C-F453BABB48A4> /usr/lib/libMobileGestalt.dylib
   0x7fff7a944000 -     0x7fff7a944fff  libOpenScriptingUtil.dylib (179.1) <4D603146-EDA5-3A74-9FF8-4F75D8BB9BC6> /usr/lib/libOpenScriptingUtil.dylib
   0x7fff7aa84000 -     0x7fff7aa85ffb  libSystem.B.dylib (1252.250.1) <C7A55258-8EB2-3202-82B5-AA56E53EE2DA> /usr/lib/libSystem.B.dylib
   0x7fff7ab01000 -     0x7fff7ab02fff  libThaiTokenizer.dylib (2.15.1) <ADB37DC3-7D9B-3E73-A72A-BCC3433C937A> /usr/lib/libThaiTokenizer.dylib
   0x7fff7ab14000 -     0x7fff7ab2affb  libapple_nghttp2.dylib (1.24.1) <6F04250A-6686-3FDC-9A8D-290C64B06502> /usr/lib/libapple_nghttp2.dylib
   0x7fff7ab2b000 -     0x7fff7ab54ffb  libarchive.2.dylib (54.250.1) <47289946-8504-3966-9127-6CE39993DC2C> /usr/lib/libarchive.2.dylib
   0x7fff7ab55000 -     0x7fff7abd4fff  libate.dylib (1.13.8) <92B44EDB-369D-3EE8-AEC5-61F8B9313DBF> /usr/lib/libate.dylib
   0x7fff7abd8000 -     0x7fff7abd8ff3  libauto.dylib (187) <3E3780E1-96F3-3A22-91C5-92F9A5805518> /usr/lib/libauto.dylib
   0x7fff7acaa000 -     0x7fff7acbaffb  libbsm.0.dylib (39.200.18) <CF381E0B-025B-364F-A83D-2527E03F1AA3> /usr/lib/libbsm.0.dylib
   0x7fff7acbb000 -     0x7fff7acc8fff  libbz2.1.0.dylib (38.200.3) <272953A1-8D36-329B-BDDB-E887B347710F> /usr/lib/libbz2.1.0.dylib
   0x7fff7acc9000 -     0x7fff7ad1cff7  libc++.1.dylib (400.9.4) <9A60A190-6C34-339F-BB3D-AACE942009A4> /usr/lib/libc++.1.dylib
   0x7fff7ad1d000 -     0x7fff7ad32ff7  libc++abi.dylib (400.17) <38C09CED-9090-3719-90F3-04A2749F5428> /usr/lib/libc++abi.dylib
   0x7fff7ad33000 -     0x7fff7ad33ff3  libcharset.1.dylib (51.200.6) <2A27E064-314C-359C-93FC-8A9B06206174> /usr/lib/libcharset.1.dylib
   0x7fff7ad34000 -     0x7fff7ad44ffb  libcmph.dylib (6.15.1) <9C52B2FE-179F-32AC-B87E-2AFC49ABF817> /usr/lib/libcmph.dylib
   0x7fff7ad45000 -     0x7fff7ad5dffb  libcompression.dylib (52.250.2) <7F4BB18C-1FB4-3825-8D8B-6E6B168774C6> /usr/lib/libcompression.dylib
   0x7fff7afd2000 -     0x7fff7afe8fff  libcoretls.dylib (155.220.1) <4C64BE3E-41E3-3020-8BB7-07E90C0C861C> /usr/lib/libcoretls.dylib
   0x7fff7afe9000 -     0x7fff7afeaff3  libcoretls_cfhelpers.dylib (155.220.1) <0959B3E9-6643-3589-8BB3-21D52CDF0EF1> /usr/lib/libcoretls_cfhelpers.dylib
   0x7fff7b496000 -     0x7fff7b4ecff3  libcups.2.dylib (462.16) <E82021D0-36AD-3FB7-AE47-A03A6947C7D0> /usr/lib/libcups.2.dylib
   0x7fff7b620000 -     0x7fff7b620fff  libenergytrace.dylib (17.200.1) <80BB567A-FD18-3497-BF97-353F57D98CDD> /usr/lib/libenergytrace.dylib
   0x7fff7b652000 -     0x7fff7b657ff7  libgermantok.dylib (17.15.2) <E5F0F794-FF27-3D64-AE52-C78C6A84DD67> /usr/lib/libgermantok.dylib
   0x7fff7b658000 -     0x7fff7b65dff7  libheimdal-asn1.dylib (520.270.1) <73F60D6F-76F8-35EF-9C86-9A81225EE4BE> /usr/lib/libheimdal-asn1.dylib
   0x7fff7b688000 -     0x7fff7b778fff  libiconv.2.dylib (51.200.6) <2047C9B7-3F74-3A95-810D-2ED8F0475A99> /usr/lib/libiconv.2.dylib
   0x7fff7b779000 -     0x7fff7b9daffb  libicucore.A.dylib (62141.0.1) <A0D63918-76E9-3C1B-B255-46F4C1DA7FE8> /usr/lib/libicucore.A.dylib
   0x7fff7ba27000 -     0x7fff7ba28fff  liblangid.dylib (128.15.1) <22D05C4F-769B-3075-ABCF-44A0EBACE028> /usr/lib/liblangid.dylib
   0x7fff7ba29000 -     0x7fff7ba41ff3  liblzma.5.dylib (10.200.3) <E1F4FD60-1CE4-37B9-AD95-29D348AF1AC0> /usr/lib/liblzma.5.dylib
   0x7fff7ba59000 -     0x7fff7bafdff7  libmecab.1.0.0.dylib (779.24.1) <A8D0379B-85FA-3B3D-89ED-5CF2C3826AB2> /usr/lib/libmecab.1.0.0.dylib
   0x7fff7bafe000 -     0x7fff7bd02fff  libmecabra.dylib (779.24.1) <D71F71E0-30E2-3DB3-B636-7DE13D51FB4B> /usr/lib/libmecabra.dylib
   0x7fff7beda000 -     0x7fff7c22bff7  libnetwork.dylib (1229.250.15) <72C7E9E3-B2BE-3300-BE1B-64606222022C> /usr/lib/libnetwork.dylib
   0x7fff7c2bd000 -     0x7fff7ca42fdf  libobjc.A.dylib (756.2) <7C312627-43CB-3234-9324-4DEA92D59F50> /usr/lib/libobjc.A.dylib
   0x7fff7ca54000 -     0x7fff7ca58ffb  libpam.2.dylib (22.200.1) <586CF87F-349C-393D-AEEB-FB75F94A5EB7> /usr/lib/libpam.2.dylib
   0x7fff7ca5b000 -     0x7fff7ca90fff  libpcap.A.dylib (79.250.3) <97B8CE1B-3EF6-3443-95EF-5659733139C9> /usr/lib/libpcap.A.dylib
   0x7fff7cba9000 -     0x7fff7cbc1ffb  libresolv.9.dylib (65.200.3) <1FB0982D-84D9-36E0-B3D8-C808891EFF50> /usr/lib/libresolv.9.dylib
   0x7fff7cc12000 -     0x7fff7cc13ff7  libspindump.dylib (267.3) <A584E403-8C95-3841-9C16-E22664A5A63F> /usr/lib/libspindump.dylib
   0x7fff7cc14000 -     0x7fff7cdf1fff  libsqlite3.dylib (274.26) <6404BA3B-BCA4-301F-B2FE-8776105A2AA3> /usr/lib/libsqlite3.dylib
   0x7fff7d00a000 -     0x7fff7d00dff7  libutil.dylib (51.200.4) <CE9B18C9-66ED-32D4-9D29-01F8FCB467B0> /usr/lib/libutil.dylib
   0x7fff7d00e000 -     0x7fff7d01bfff  libxar.1.dylib (417.1) <39CCF46B-C81A-34B1-92A1-58C4E5DA846E> /usr/lib/libxar.1.dylib
   0x7fff7d020000 -     0x7fff7d103fff  libxml2.2.dylib (32.19) <E07AB10E-E2E6-33F2-8550-C24A0EB8FEAC> /usr/lib/libxml2.2.dylib
   0x7fff7d104000 -     0x7fff7d12cff3  libxslt.1.dylib (16.7.1) <4A5CB7D5-50F8-36BF-8A80-D526C57EB5D9> /usr/lib/libxslt.1.dylib
   0x7fff7d12d000 -     0x7fff7d13fff7  libz.1.dylib (70.200.4) <B048FC1F-058F-3A08-A1FE-81D5308CB3E6> /usr/lib/libz.1.dylib
   0x7fff7d923000 -     0x7fff7d927ff3  libcache.dylib (81) <1987D1E1-DB11-3291-B12A-EBD55848E02D> /usr/lib/system/libcache.dylib
   0x7fff7d928000 -     0x7fff7d932ff3  libcommonCrypto.dylib (60118.250.2) <1765BB6E-6784-3653-B16B-CB839721DC9A> /usr/lib/system/libcommonCrypto.dylib
   0x7fff7d933000 -     0x7fff7d93aff7  libcompiler_rt.dylib (63.4) <5212BA7B-B7EA-37B4-AF6E-AC4F507EDFB8> /usr/lib/system/libcompiler_rt.dylib
   0x7fff7d93b000 -     0x7fff7d944ff7  libcopyfile.dylib (146.250.1) <98CD00CD-9B91-3B5C-A9DB-842638050FA8> /usr/lib/system/libcopyfile.dylib
   0x7fff7d945000 -     0x7fff7d9c9fc3  libcorecrypto.dylib (602.260.2) <01464D24-570C-3B83-9D18-467769E0FCDD> /usr/lib/system/libcorecrypto.dylib
   0x7fff7da50000 -     0x7fff7da89ff7  libdispatch.dylib (1008.270.1) <97273678-E94C-3C8C-89F6-2E2020F4B43B> /usr/lib/system/libdispatch.dylib
   0x7fff7da8a000 -     0x7fff7dab6ff7  libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib
   0x7fff7dab7000 -     0x7fff7dab7ffb  libkeymgr.dylib (30) <0D0F9CA2-8D5A-3273-8723-59987B5827F2> /usr/lib/system/libkeymgr.dylib
   0x7fff7dab8000 -     0x7fff7dac4ff3  libkxld.dylib (4903.278.56) <A3FF22FA-4AD4-3FF3-9891-B34482DC8572> /usr/lib/system/libkxld.dylib
   0x7fff7dac5000 -     0x7fff7dac5ff7  liblaunch.dylib (1336.261.6) <1F0EEC6F-4D08-38E6-ACF9-6E44D328931F> /usr/lib/system/liblaunch.dylib
   0x7fff7dac6000 -     0x7fff7dacbfff  libmacho.dylib (927.0.3) <A377D608-77AB-3F6E-90F0-B4F251A5C12F> /usr/lib/system/libmacho.dylib
   0x7fff7dacc000 -     0x7fff7daceff7  libquarantine.dylib (86.270.1) <3F36A3D6-9606-3D90-B520-809BAEF981C3> /usr/lib/system/libquarantine.dylib
   0x7fff7dacf000 -     0x7fff7dad0ff7  libremovefile.dylib (45.200.2) <9FBEB2FF-EEBE-31BC-BCFC-C71F8D0E99B6> /usr/lib/system/libremovefile.dylib
   0x7fff7dad1000 -     0x7fff7dae8ff3  libsystem_asl.dylib (356.200.4) <A62A7249-38B8-33FA-9875-F1852590796C> /usr/lib/system/libsystem_asl.dylib
   0x7fff7dae9000 -     0x7fff7dae9ff7  libsystem_blocks.dylib (73) <A453E8EE-860D-3CED-B5DC-BE54E9DB4348> /usr/lib/system/libsystem_blocks.dylib
   0x7fff7daea000 -     0x7fff7db71fff  libsystem_c.dylib (1272.250.1) <7EDACF78-2FA3-35B8-B051-D70475A35117> /usr/lib/system/libsystem_c.dylib
   0x7fff7db72000 -     0x7fff7db75ffb  libsystem_configuration.dylib (963.270.3) <2B4A836D-68A4-33E6-8D48-CD4486B03387> /usr/lib/system/libsystem_configuration.dylib
   0x7fff7db76000 -     0x7fff7db79ff7  libsystem_coreservices.dylib (66) <719F75A4-74C5-3BA6-A09E-0C5A3E5889D7> /usr/lib/system/libsystem_coreservices.dylib
   0x7fff7db7a000 -     0x7fff7db80fff  libsystem_darwin.dylib (1272.250.1) <EC9B39A5-9592-3577-8997-7DC721D20D8C> /usr/lib/system/libsystem_darwin.dylib
   0x7fff7db81000 -     0x7fff7db87ffb  libsystem_dnssd.dylib (878.270.3) <D5352ABD-0311-3327-8E64-93F29EB19BF1> /usr/lib/system/libsystem_dnssd.dylib
   0x7fff7db88000 -     0x7fff7dbd3ffb  libsystem_info.dylib (517.200.9) <D09D5AE0-2FDC-3A6D-93EC-729F931B1457> /usr/lib/system/libsystem_info.dylib
   0x7fff7dbd4000 -     0x7fff7dbfcff7  libsystem_kernel.dylib (4903.278.56) <5B0F1BF0-E2F4-3753-87B6-6F91C594F59E> /usr/lib/system/libsystem_kernel.dylib
   0x7fff7dbfd000 -     0x7fff7dc48ff7  libsystem_m.dylib (3158.200.7) <F19B6DB7-014F-3820-831F-389CCDA06EF6> /usr/lib/system/libsystem_m.dylib
   0x7fff7dc49000 -     0x7fff7dc73fff  libsystem_malloc.dylib (166.270.1) <011F3AD0-8E6A-3A89-AE64-6E5F6840F30A> /usr/lib/system/libsystem_malloc.dylib
   0x7fff7dc74000 -     0x7fff7dc7eff7  libsystem_networkextension.dylib (767.250.2) <FF06F13A-AEFE-3A27-A073-910EF78AEA36> /usr/lib/system/libsystem_networkextension.dylib
   0x7fff7dc7f000 -     0x7fff7dc86fff  libsystem_notify.dylib (172.200.21) <145B5CFC-CF73-33CE-BD3D-E8DDE268FFDE> /usr/lib/system/libsystem_notify.dylib
   0x7fff7dc87000 -     0x7fff7dc90fef  libsystem_platform.dylib (177.270.1) <9D1FE5E4-EB7D-3B3F-A8D1-A96D9CF1348C> /usr/lib/system/libsystem_platform.dylib
   0x7fff7dc91000 -     0x7fff7dc9bff7  libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib
   0x7fff7dc9c000 -     0x7fff7dc9fff7  libsystem_sandbox.dylib (851.270.5) <20D11F30-783F-3A56-9BD2-6CF38C049332> /usr/lib/system/libsystem_sandbox.dylib
   0x7fff7dca0000 -     0x7fff7dca2ff3  libsystem_secinit.dylib (30.260.2) <EF1EA47B-7B22-35E8-BD9B-F7003DCB96AE> /usr/lib/system/libsystem_secinit.dylib
   0x7fff7dca3000 -     0x7fff7dcaaff3  libsystem_symptoms.dylib (820.267.2) <0DA60956-0403-3456-9D6A-11F2DB9E3819> /usr/lib/system/libsystem_symptoms.dylib
   0x7fff7dcab000 -     0x7fff7dcc0ff7  libsystem_trace.dylib (906.260.3) <5B6FAE61-EF5C-381F-B71B-9B6F6428FEE2> /usr/lib/system/libsystem_trace.dylib
   0x7fff7dcc2000 -     0x7fff7dcc7ffb  libunwind.dylib (35.4) <24A97A67-F017-3CFC-B0D0-6BD0224B1336> /usr/lib/system/libunwind.dylib
   0x7fff7dcc8000 -     0x7fff7dcf7fff  libxpc.dylib (1336.261.6) <522FA3AF-D3B1-3283-8EF4-8B17CB237B65> /usr/lib/system/libxpc.dylib
External Modification Summary:
 Calls made by other processes targeting this process:
   task_for_pid: 6729
   thread_create: 0
   thread_set_state: 0
 Calls made by this process:
   task_for_pid: 0
   thread_create: 0
   thread_set_state: 0
 Calls made by all processes on this machine:
   task_for_pid: 8985034
   thread_create: 0
   thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=408.9M resident=0K(0%) swapped_out_or_unallocated=408.9M(100%)
Writable regions: Total=623.5M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=623.5M(100%)
                               VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               128K        1
Activity Tracing                   256K        1
CG backing stores                 1160K        2
CG image                           108K       10
CoreAnimation                      308K       15
CoreGraphics                         8K        1
CoreImage                           24K        2
CoreUI image data                 1380K       15
CoreUI image file                  196K        3
Foundation                           4K        1
Kernel Alloc Once                    8K        1
MALLOC                           225.5M       31
MALLOC guard page                   32K        7
MALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)
Memory Tag 242                      12K        1
STACK GUARD                       56.0M        6
Stack                             10.5M        6
VM_ALLOCATE                        232K       17
__DATA                            25.5M      247
__FONT_DATA                          4K        1
__LINKEDIT                       225.6M        4
__TEXT                           183.2M      251
__UNICODE                          564K        1
mapped file                       53.2M       82
shared memory                      636K       11
TOTAL                              1.1G      718
TOTAL, minus reserved VM space   784.6M      718
Model: MacBookPro11,5, BootROM 426.0.0.0.0, 4 processors, Intel Core i7, 2.8 GHz, 16 GB, SMC 2.30f2
Graphics: kHW_AMDRadeonR9M370XItem, AMD Radeon R9 M370X, spdisplays_pcie_device, 2 GB
Graphics: kHW_IntelIrisProItem, Intel Iris Pro, spdisplays_builtin
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533642465238412D50422020
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533642465238412D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x152), Broadcom BCM43xx 1.0 (7.77.61.3 AirPortDriverBrcmNIC-1305.11)
Bluetooth: Version 6.0.14d12, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SM1024G, 1 TB
USB Device: USB 3.0 Bus
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Bluetooth USB Host Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 27.1
Feb 24, 2021 1:37:37 pm EST
I'll forward this to our development department and ask for their input on the issue to see if there's anything we can do to fix it. Sorry for the inconvenience.
I'll get back to you with an update on the issue shortly.
J dGelder, User (Posts: 2)
Mar 15, 2021 1:35:12 am EDT
Maybe i overlooked something, but starting a connection from the commandline is not possible (on Linux). All I can find are the windows options, but they don't work.
What are possible commands available?
Mar 15, 2021 4:16:30 pm EDT
Unfortunately, there are no parameters for Viewer for Linux available yet. However, we'll make sure to notify our  users and update the related Documentation page once the parameters for Viewer for Mac/Linux are available as well. Sorry for the inconvenience.
Jan, User (Posts: 2)
Mar 22, 2021 7:53:57 am EDT
Thank you for you quick response.
When will this feature be available? Our customer does want to open a connection from an application we are developing, and if we can open directly the correct connection, without having the operator to look in the addressbook.
And is a roadmap available when which features will be released?
