Touch screen
Jack Tob, User (Posts: 3)
Feb 24, 2018 11:39:52 am EST
Host version: I just download it today for a Windows 10 PC
Viewer: I just download it today for an Android 7.0 tablet (Archos)
How can I use the touch screen of my tablet when viewing PC screens?
Conrad, Support (Posts: 3088)
Feb 26, 2018 5:19:35 am EST
Hello Jack,
Could you please clarify what exactly you mean by using the touch screen? Currently, the mobile client allows you to move the remote mouse pointer and send keystrokes.
Feb 26, 2018 6:10:14 am EST
Hello Conrad,
Thank you for your prompt answer.
With using the "touch screen" of my Android tablet I mean the possibility to:
Tap to click, tab and hold to click right, drag, and so on, without using the mouse and without seeing the mouse pointer.
Here an example of usage:
I have on my Windows PC a MS Access application. MS Access can't run on Android. However with a remote utility I can visualise this application on my Android tablet. And I want to tab on buttons of the MS Access program without moving a mouse.
[censored] provides this functionality; there is an on/off setting for "Show remote cursor". When I chose "off", I can tab directly to activate a button...
Feb 26, 2018 2:04:53 pm EST
Hello Jack,
I see. But unfortunately, so far this feature is not available. We will add it to our list of suggestions.
Feb 27, 2018 3:45:20 am EST
Thank you, Conrad. I will follow the further evolution of your software.
