Trying to create an installer - Problem
Doing the MSFT easy fix for the TLS fixed the issue for me on Win 7 and then a reboot was necessary.
https://support.microsoft.com/en-us/help/3140245/update-to-enable-tls-1-1-and-tls-1-2-as-default-secure-protocols-in-wi
Edited:Rob Barrett - Dec 08, 2020 11:53:39 am EST
Hello Rob,
I'm glad to hear that it works for you now!
Also, I with there was a way to do a simple update via selecting my newly created file.
Actually, it's possible to do so via the Remote Install Tool as described in this tutorial on the Advanced Update.
Please note that when Simple Update is used, it's possible to update the Host's version only, i.e. without updating any existing Host settings.
