Hello Arman,
Arman Aminloo wrote:
Did you upgrade your v. 6.x.x.x key to v. 7.x.x.x key using this form.
We have released an update. Please, download 7.0.0.1 from the main download page.
You can also use Automatic update (self-update) to update to 7.0.0.1.
We appreciate any feedback. Thanks.
Thank you for fixing the bug. It looks it's working well. The bug descibed at topic: RU Server 3.0 & screen savers is still observed - when screen saver is on or the screen is off - there is no possibily to connect. The workaround: start "power management" and switch display on. After that it' spossible to connect.
After updating to 7.0.0.1 the problem with the remote connection drops is solved.
Thanks for fixing!
thank you! this better than ever :)
I can no longer carry out the File Transfer function after updating to ver 7 this morning and connection dropping often
You need to upgrade to 7.0.0.1.
I have upgraded to 7.0.0.1 but everytime i click the lightning symbol for file transfer it comes up with error " Unable to open Directory.....was ok before update
In my case the problem occured when a host was not version 7. You have to upgrade Viewer and hosts to v.7.
The same problem was in beta.
Hi Mike,
This is from our release notes:
