Conrad Sallian, Support (Posts: 3023)
Feb 27, 2021 11:36:13 am EST
Hello Arman,
Arman Aminloo wrote:
Did you upgrade your v. 6.x.x.x key to v. 7.x.x.x key using this form.
Feb 28, 2021 10:01:36 am EST
We have released an update. Please, download 7.0.0.1 from the main download page.
You can also use Automatic update (self-update) to update to 7.0.0.1.
We appreciate any feedback. Thanks.
Michał Kokociński, User (Posts: 8)
Feb 28, 2021 12:00:18 pm EST
Thank you for fixing the bug. It looks it's working well. The bug descibed at topic: RU Server 3.0 & screen savers is still observed - when screen saver is on or the screen is off - there is no possibily to connect. The workaround: start "power management" and switch display on. After that it' spossible to connect.
TheDutchJewel, User (Posts: 4)
Feb 28, 2021 12:00:42 pm EST
After updating to 7.0.0.1 the problem with the remote connection drops is solved.
Thanks for fixing!
Andy Jackson, User (Posts: 7)
Feb 28, 2021 12:36:24 pm EST
thank you! this better than ever :)
Mike butterworth, User (Posts: 6)
Mar 01, 2021 6:03:42 am EST
I can no longer carry out the File Transfer function after updating to ver 7 this morning and connection dropping often
Mar 01, 2021 6:05:22 am EST
You need to upgrade to 7.0.0.1.
Mar 01, 2021 6:09:24 am EST
I have upgraded to 7.0.0.1 but everytime i click the lightning symbol for file transfer it comes up with error " Unable to open Directory.....was ok before update
Mar 01, 2021 6:10:56 am EST
In my case the problem occured when a host was not version 7. You have to upgrade Viewer and hosts to v.7.
The same problem was in beta.
Mar 01, 2021 7:01:43 am EST
Hi Mike,
This is from our release notes:
